Originally Posted by NancyLH
We upgraded from a 1984 travel trailer to a 2017 35' Cherokee BH as our lake getaway here in Minnesota. The trailer will be parked at the lake year-round, although we may take a road trip with it occasionally.
We will not use it in the winter, so we have drained all water and put about 6 gallons of antifreeze in the system. We also pulled the batteries and put a cover on the trailer and the tires.
Other maintenance we plan is annual waxing and roof coating.
So I think I have a simple question ... are there other things we need to think about for regular maintenance to make sure it's road worthy if we choose to take hit the road in awhile?
We leave a small (30 pt.) dehumidifier running all the time. We put it in the shower, without the collector tank. (You have to wedge the tank switch On.) We open the gray tank valve and let the collected water out, so it doesn't freeze in the waste pipe. This keeps the trailer fresh and mildew-free all year.
For the trailer at home, we just let the water out on the drive. For the trailer on a campground site, we connect the sewage tote and let the water collect there.
Most modern dehumidifiers (including our two) won't run when the air temperature gets below 50 or 60F, so they aren't damaged by frigid winters.
Did you say six gallons? That's a lot for winterizing. Did you bypass the water heater first?
