04-13-2020, 09:35 PM
Morryde Quick Connect anybody have it?
Hey gang! Hope you all survived winter and are holding up through Corona.
Over the winter, I decided I wanted to add a better step to my Catalina 273TBS. I was excited about the Morryde Step Above, but the measurements of my door didn't match with anything they offered. I contacted the manufacturer about modifications and they suggested buying the Quick Connect Step instead. Instead of being permanently mounted to the threshold (and stowing up into the doorway) this one has two clips attached to the outside of the camper and attaches when you get parked. My reason for wanting the step is I feel like every time The Wife and kids go in and out it feels like they are jumping on each step. The camper bounces and the steps never feel that stable.
My question is... Has anybody used the Quick Connect Step? Do you like it? Why or why not? And where do you stow it during travel?
2015 Coachmen Catalina 273TBS pulled by a 2019 F150 Platinum.
04-13-2020, 09:45 PM
In other threads, a number of folks speak highly of Torklift Revolution Uprising Steps. I am considering one of these to replace the drawbridge step which now comes standard - I can't lower the OE step in my garage. Contacting Torklift it seems they have a large selection of sizes for any trailer.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
04-13-2020, 10:19 PM
I have the Torklift GlowStep Revolution it has legs that sit on the ground making it very strong and stable and is a direct replacement for your steps only 4 bolts
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
04-13-2020, 10:26 PM
OOh.. Those are interesting! I like the flexibility, but I see two problems...
1) Cost is significantly higher.
2) Checking their site, none of their models seems to fit my measurements. I have a set of 2 steps mounted below the frame (there isn't a cutout in the sidewall of the trailer, the steps mount below the wall of the trailer). The box is 26 inches wide and under 11 inches tall. It doesn't seem to fit the needs of the Torklift unless I buy the revolution. And those things look to be about an extra $300+.
What I like about the Quick Connect is that I can leave the factory mounted steps on and use those for quick in-and-outs at the storage lot or for roadside stops on travel days.
04-13-2020, 11:59 PM
I have a set of the Revolution under mount steps. Stainless steel and aluminum. I expect them to remain looking like new for a very long time. I found that the steps are significantly lighter than the OEMs. And an added benefit, my DW often had trouble deploying or stowing the OEM steps, she has no trouble with the Torklifts.
I'd take measurements of your trailer - space between the mount brackets and distance to ground and contact Torklift. I'm confident that they will help you find the correct fitment for your trailer. You might also send them a couple of pictures of your setup.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
04-14-2020, 12:40 PM
Stabilization
I bought these. Cheap and 5 stars.
04-14-2020, 09:40 PM
Well, I looked into the Torklift setup. I REALLY liked it. I emailed the my camper's specs because they didn't seem to fall within anything on their site. They told me which model should work. Unfortunately, I think it is more cost than I can justify. They are about $590. Conversely, I was able to find the Morryde Quick Connect for $180. I am hoping that, since it comes off during travel and I will be able to leave the original camper steps installed, I won't have the concern other people have with not being able to open the Morryde steps in close quarters. Now just to see when I can get a trip in that isn't cancelled.
04-15-2020, 06:22 AM
MCTroy
Love this idea... found the 3 steps on Amazon and other sites about $250. Where did you find them for $180? I like that price!
04-15-2020, 07:49 AM
The cheapest I found them was on a site called camperid.com they had the step I need for about $200, plus they offer a 10% discount for first responders and veterans.
04-15-2020, 08:05 AM
MCTroy
Thanks!
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
04-15-2020, 08:54 AM
Take a look at C.R. Brophy Scissor Steps. Amazon and Etrailer sell them.
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
