Old 04-30-2020, 04:12 PM   #1
A2pfunk's Avatar
Morryde Quick Connect Step review and install (I made my first video)
So I had been interested in installing a Morryde Step Above in my Coachmen Catalina 273 TBS. However, it would not fit in my unit without modifications. Instead, I found the Quick Connect. Instead of being permanently attached and folding into the door, this model clips into the camper exterior. The pros are that you can use still get into and out of the camper even when it's parked in tight quarters, such as a storage lot. You can still also use the original factory steps if you want. They are incredibly stable and eliminate movement from the camper when entering/exiting. The cons are that you need to find a place to store it while traveling. Overall, I'm very impressed and happy with it. I got it for $183.
In other news, I've always been intrigued by folks who make their own videos. So I used this as an opportunity to learn how to make my own video. It was a lot easier than I expected. The only problem was trying to get it to export in HD. Feel free to check it out.
https://youtu.be/VBgnWsRuiqA
2015 Coachmen Catalina 273TBS pulled by a 2019 F150 Platinum.
A2pfunk is offline   Reply With Quote
