Old 06-11-2018, 03:12 PM   #1
Need help with torque specs
I have a 2018 Cruise Lite 263bhxl with 14 in steel wheels. I can't seem to find a definitive answer to what the lug nuts should be torqued at. The manual gives generic answers and the wheel says to refer to the manual. Can someone help? Thanks a ton!
Jmac1 is offline   Reply With Quote
Old 06-11-2018, 03:17 PM   #2
Here is a wheel lug torque spec chart (from etrailer)
For 1/2" wheel studs and a 14" steel trailer wheel you will use a torque range of 75-to-85-ft. lbs.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 06-11-2018, 03:23 PM   #3
Scoundrel
HangDiver's Avatar
I torqued my 1/2" stud, steel wheels, 14" rim to 90lbs. Looking at the chart above maybe I should loosen them and retorque to 85lbs?
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 06-11-2018, 04:26 PM   #4
Rollin Okie's Avatar
Have you looked to see if there is a sticker above your tires telling the torque. I looked everywhere, manuals, net, ask, then looked above the wheels and found the sticker.
I John 5:13
2007 Silverback 30LSTS
2006 F250 Super Duty Crew 6.0
Rollin Okie is offline   Reply With Quote
Old 06-11-2018, 05:17 PM   #5
I have 14" wheels and 1/2" studs. The sticker on the side of the trailer, right above the axle say to torque to 100.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 06-11-2018, 06:20 PM   #6
There is a sticker that says 100 ft. lbs unless otherwise stated by manufacturer. The manual says 85 to 95 or manufacturers specs and etrailer claims 75 to 85.
I torqued to 90ft. lbs and am calling it good. Thanks for the help guys.
Old 06-12-2018, 12:09 AM   #7
My sticker is on the front of my trailer. 105 ft lbs. Discount Tire torqued them to 100 ft lbs before I noticed the sticker. I'm not going to sweat 5 ft lbs.
2019 Silverado LTZ 1500 6.2L 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 3.42
2015 Jeep Wrangler Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is online now   Reply With Quote
Old 06-12-2018, 02:40 PM   #8
Torques have a +/- value. For 85 lb/ft, being over 5 lbs is not going to hurt anything.
ard58 is offline   Reply With Quote
Old 06-12-2018, 04:35 PM   #9
Torque
Short answer----NO
pdqparalegal1 is offline   Reply With Quote
Old 06-12-2018, 06:19 PM   #10
Tom48's Avatar
If you have lippert LCI axles, the lippert manual, which can be found online has infinite detail for all axle related maintenance.
But in short in a three stage process of tightening, they take all
Half inch lugs up to between 90 and 120 ft/lbs of torque.
Tom48 is offline   Reply With Quote
Old 06-12-2018, 06:23 PM   #11
Tom48's Avatar
The better thing to SWEAT is to recheck them about 50 miles after you have them off. Torque may vary by then. Then I rechecked every few trips. Torque wrench and 3/4 inch socket travel with me.
Old 06-13-2018, 02:11 PM   #12
Mowgli64's Avatar
And while we are talking about torque make sure you check all the hitch bolts also. I was just checking mine before our trip to the Gettysburg rally and found more then one not tight enough. So I must say thank you to all those that keep bugging those of us who keep putting things off
2015 Wildwood X-Lite 271RBXL
2019 Ford F350 CrewCab Diesel
(2013 Ford F150 Crewcab Ecoboost traded)
Mowgli64 is offline   Reply With Quote
