05-23-2020, 12:23 PM
New Lippert Floe Water Line Flusher System
Anyone given this product any research and thought? I notice that they focus on your fresh water lines and say nothing about flushing the gray/black pipes so this would not be a true alternative solution to winterizing, right?
And if all this does is flush your water lines so you don't use "stale" water, couldn't you do that by simply running your water a couple of minutes?
For $250, I was hoping for a complete winterizing solution!
Thanks for your input!
ArkRVHog
2018 Forester Model 2801 QSF
Katy, TX
OTR 2024-22 / 2023-29 / 2022-52
2021-51 / 2020-29 / 2019-71 / 2018-49
05-23-2020, 12:33 PM
Do you have a link or a model number or something?
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
05-23-2020, 08:49 PM
https://store.lci1.com/flo-integrate...wn-system.html
If this link doesn't work, Google Lippert Components Floe System.
ArkRVHog
Katy, TX
05-23-2020, 09:03 PM
I already have an air compressor, so buying a $5 air hose fitting that screws onto the city water connection was all I needed to do. I have a second fitting that screws onto my black tank flush, as I don't like mixing fresh water and black/gray water equipment. I also use RV antifreeze once I've purged my water lines. Most people don't even bother using air to purge their water lines if they're going use RV antifreeze.
Quite frankly, I think this device is more a waste of money than anything else. I see no benefit in getting one.
05-24-2020, 12:18 PM
Dahagen
As mentioned by AKErik, a cheap air compressor works great for flushing the water system when you winterize. And I just run fresh water through the system to clear out the 'old' water. Unless you winterize your water system a lot, I see no need for the Lippert thing.
05-24-2020, 12:44 PM
BUTTT it uses:
"Mobile Compressed Air Technology"
Based on the apparent size. It is not much of a compressor. And one review says very noisy. Also probably takes forever to fill the system with air each time.
For $250 you can buy 2 or 3 good compressors that you can use for other things. Like tires and beach toys or whatever.
Not worth it IMHO.
Have fun.
05-24-2020, 01:05 PM
Add my vote for a gimmick that is not worth the money at all.
05-24-2020, 01:27 PM
X2
A lot $$ for something you typically use once per year. Besides that, you should probably have an air compressor anyway - so kill 2 birds with one stone.
2011 Traverse LT, 3.6L, FWD
05-24-2020, 02:59 PM
x3... Get a solid air compressor and take care of your water, your tires and inflatable toys for 1/2 the cost of the Lippert.
________
Cam
2015 Georgetown 280DS
05-24-2020, 03:25 PM
UK English vs US English
Thaenks for your input!
It appears to be a complete, permanently installed winterizing solution. Apparently in the UK, "flush" can be used to describe air displacing water. In the US it would more likely be used to describe fresh water displacing stale water.
Regardless, it does seem like an unnecessary toy. Others have mentioned using their compressors to purge their systems. Some, like me, use the built-in water pump to displace the water with pink RV antifreeze.
I always wonder whether the folks using compressors are using oil-free compressors. My compressor has an oil-filled crankcase and I am reluctant to use it on the water system.
Larry
05-24-2020, 04:23 PM
Good point.
I don't know about other compressors. Mine is a 25 year old Campbell Hausfieldor something. The oil is put into the tool. So downstream from the compressor. No issue.i
05-24-2020, 04:55 PM
My pancake compressor is oil free. Set the regulator for about 30 lbs and let it blow.
05-24-2020, 05:03 PM
Oil bypass?
Originally Posted by U.S.ArmyVeteran
Good point.
I don't know about other compressors. Mine is a 25 year old Campbell Hausfield or something. The oil is put into the tool. So downstream from the compressor. No issue.i
The compressors with oil in the crankcase do pass a bit of oil in the compressed air. As the piston retracts to fill with air, there's a slight vacuum. Most air comes in through the intake. But minute amounts of oil from the cylinder walls can be pulled past the piston rings into compression chamber and on into the tank and hose.
If you look at the Harbor Freight catalog, for example, you will see both kinds. My Harbor Freight compressor does have oil in the crankcase but that does not provide enough oil for tools--I dribble some into each tool. My son has an airbrush compressor--might also be Campbell-Hausfeld--that is oil-free. It has carbon piston rings.
The auto painters won't go near an oil-filled compressor. They know that it can affect the paint's bonding to the surface being painted.
Larry
05-24-2020, 05:26 PM
Retired
Video on the website says in “charges” to 15 psi. Does that imply that it does not provide a continuous 15 psi? Doesn’t seem like a lot of air pressure.
I use 25 to 30 psi with my pancake compressor.
05-27-2020, 10:20 AM
AKA: 'tiredTeacher
And … did you notice how they say it "prepares your RV for winterizing"?
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
05-27-2020, 10:42 AM
Prepare can be read many ways.
If someone prepares a bath for someone else, that means it is ready for that person to bathe in.
If you say you are going to prepare a speech, that means you have outlined/written the words you want to convey and are ready to give it.
I believe in the case of the Floe system, it means just that... it has prepared your R/V for winterizing... meaning it has done what the Floe was designed to do. If YOU choose to do something additional/different when winterizing, that is no fault of the Floe not doing what it is advertised to do.
I think the manufacturer is simply trying to provide an option for those not capable of buying/using a separate air compressor nor having the ability to sanitize their system in the conventional manner we all seem accustomed to.
You have to remember... there ARE folks out there who don't have a clue.
I'm not saying that may be anyone on this forum or being demeaning in any way.
It is simply a fact that some folks cannot do things others can. Whether that be from lack of knowledge, a disability, or they'd just rather pay someone else to do it.
This device may fill that need.
I have no dog in the Floe hunt but I can see where it could serve a purpose for some. Could it be called a 'sales gimmick'... sure... but so are a lot of other R/V related things.
