Old 09-21-2018, 04:51 PM   #161
cburchel's Avatar
I'm guessing taking some of the rattle noise away. Mine has a little rattle noise and if you hold the plastic in spots it is alot more quite.
2006 Chevrolet 2500 Duramax with some added power / 2017 Salem Hemisphere 29BHHL
cburchel is offline   Reply With Quote
Old 09-21-2018, 05:01 PM   #162
ECVCHAMP's Avatar
Originally Posted by NMWildcat View Post
I don't get how this would help,. Could you explain?????
They worked so hare on making it quiet, they made the case restrictive for the air going into the engine. there are several you tube videos about it.
ECVCHAMP is offline   Reply With Quote
Old 09-21-2018, 05:15 PM   #163
NMWildcat's Avatar
Ah, thanks. One more thing to add to my predator list
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 09-21-2018, 08:39 PM   #164
2007 WildCat 32QBBS
18CrewDually's Avatar
I recall seeing a video on tube where a guy used a Uni-bit and made a bunch of ventilation holes in one of the covers. If I find it I'll post the link.
18CrewDually is offline   Reply With Quote
Old 09-22-2018, 01:57 PM   #165
rracer5's Avatar
I have a Predator 3500 and love it, the only thing is I take off the oil fill door so it runs smoother.
I just bought mine a week ago. Still going through the break in period. Will post further as time/testing goes on. And yes, the wheel lock metal plate does rattle but, that's an easy fix.
Some had complained that sometime after the first couple hours the engine would start to surge. One guy took the oil door off while it was running and it suddenly started running smooth again. The deduction was that it was starving for air and removing the door (or drilling holes as mentioned) allowed more air to the carburator. Hopefully this newer batch has been upgraded by the HF manufacturer......stay tuned.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-22-2018, 09:50 PM   #166
Originally Posted by kenh View Post
I've been considering the Predator 3500 and a couple of Champion models. The Predator 3500 documentation says it has a spark arrestor but it does not claim it to be USDA approved. This might be an omission from the specs. The price looks good and so do the reviews.
In comparing specifications, I noticed that some specify they have USDA or USDA/USFS approved spark arrestors, some do not. Champion 100263 and 100264 specify they are equipped with a USDA approved spark arrestor.
https://www.fs.usda.gov/Internet/FSE...rdb5371474.pdf
6. Operating or using any internal or external combustion engine without a spark
arresting device properly installed, maintained, and in effective working order
meeting either:
o Department of Agriculture, Forest Service Standard 5100-1a; or
o Appropriate Society of Automotive Engineers (SAE recommended practice J335 (b) and J350 (a); 36 C.R.R. § 261.52(j)
It looks like using an internal combustion engine without a "USDA Approved" spark arrestor is illegal on Federal land. Could be worth considering depending on where you intend to camp and use the inverter.
Ken
I went to Northern Tool and purchased their Spark Arrester for their Powerhorse 3500, which is USDA Certified and it fits perfectly. I will just keep the receipt in a safe place, in case a ranger questions me. It was only around $15.00. I hopes this helps with any concerns. I love my Predator 3500, so far. I am still breaking it in and have 18 hours on it. So far, it is super quiet and has had no problems. I purchased some break in oil and changed the oil at 1, 2, and 8 hours. Lots of metal shavings at 1 and 2 and not as much at 8 hours. I hope this helps.
Farris is offline   Reply With Quote
Old 11-22-2018, 10:33 PM   #167
babalu7420's Avatar
Bought this last summer & had no problems using it on our RV running the AC. It is quiet running. Price is right. I would recommend buying it. Break it in as suggested,change the oil & use fuel stabilizer.
babalu2018 Forest River Flagstaff 27BHWS, Tow veh. 2016 Chevy 2500 double cab. w/6.0 eng., 6 spd. trans w/4.10 rear gear. Equalizer anti sway 10k WDH, F.R.O.G. Member
babalu7420 is offline   Reply With Quote
Old 11-23-2018, 12:25 AM   #168
CincyGus's Avatar
Bought in September, did the 5 hour break in and ran it about 18 hrs when the power was off due to an ice storm last week to use the camper to sleep in. I previously had a Champion 4000 open frame contractor genny and what a difference. I've camped next to plenty of the Honda 3500's and they are great gennys but I'll put this one up against them for quietness. If it holds up, it certainly will win for value being about 2/3rds the cost.
Oil changes are easy, Air filters not bad to get to and I'm pleased with the way it runs everything as long as I don't throw two high powered users (AC, Coffee maker, hair dryer, Microwave) at it at the same time.
The Honda 3500's are clearly the top performers but if like me, the price just doesn't work for you because of the limited amount of boondocking you do, the Predator is a good fit.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 11-24-2018, 09:23 AM   #169
fredoe61's Avatar
For the price its outstanding.
fredoe61 is offline   Reply With Quote
Old 11-24-2018, 11:11 AM   #170
rracer5's Avatar
Breaking mine in 1 hour at a time whenever I feel like opening the tonneau cover on the truck on a nice day and firing it up. On hour 3 now and it's still running smoothly. The only thing I noticed is that it cranks over for around 5 or 6 seconds before it starts. Could be I miscalculated the amount of Stabil I mixed making it hard to start? But, when it does fire up, it runs smooth. Probably will change the oil after the next hour.
Black Friday weekend special $679.
Old 11-24-2018, 04:02 PM   #171
fredoe61's Avatar
I never got the surge problem but I did buy the extended warranty where at the end of the whole warranty period I'll just trade it in for a brand new one again. I dont think you can beat that gen for the price. Only prob is the weight.
Old 11-24-2018, 04:07 PM   #172
Use non-oxy gas if at all possible.
cra_fizzer is offline   Reply With Quote
Old 11-25-2018, 10:23 AM   #173
rracer5's Avatar
I got the extended warranty also. How does that "trade it" thing work?
Do you mean ethanol free gasoline?
Old 11-25-2018, 10:39 AM   #174
Anyone have a problem w this unit stopping on its own? And how they fixed it? I used Stabil stabilizer as recommended in regular unleaded 87 octane gas. 25 hours total usage. Thought maybe wind had something to do with it but even shielding didn’t help. Only once has it run continuously 8 hours. Usually quits after a couple hours, up to 5. Seriously considering taking it back. Bought 2 year warranty.
Plaroche is offline   Reply With Quote
Old 11-25-2018, 11:40 AM   #175
rracer5's Avatar
Oil level ok? Maybe it's borderline filled. Try putting another ounce of oil in it. Check the connection on the low oil switch...loose??
If it still quits, take it back....they'll give you a new one.
Old 11-25-2018, 12:39 PM   #176
Quits on me
Ya I made sure and topped off oil. Checked a few times. Not a power demand issue either, last time I was running it through night with only dehumidifier running and it quit. I’ll probably just take back unless anyone has any other ideas.
Old 11-25-2018, 01:52 PM   #177
fredoe61's Avatar
After the manufacturers warranty ends your extended warranty kicks in. I think that's 2 year extension. Wait till the last cpl of months and take it to harbor freight and trade it in. You may have to say it's not working correctly but they will give you a new one. This is what they told me when I bought the extension otherwise I wouldnt have got it. I know others that's done the same thing.
Old 11-25-2018, 04:04 PM   #178
Free generator replacement for life!
I'll add this to the things that make me shake my head.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 11-25-2018, 04:06 PM   #179
fredoe61's Avatar
I dont think you can add another extended warranty to the replacement so it's not for life but it's still a pretty good deal.
Old 11-25-2018, 04:13 PM   #180
Leave the gas cap loose? Perhaps pulling a vacuum on the tank?
aeblank is offline   Reply With Quote
3500, 500, generator, inverter
