Old 01-31-2019, 06:54 PM   #21
frank4711's Avatar
Anyone use TIMBREN SUSPENSION ENHANCEMENT SYSTEMS ... my hitch installer likes this better than air bags ... Thanks
frank4711 is offline   Reply With Quote
Old 01-31-2019, 06:56 PM   #22
frank4711's Avatar
I am thinking of going with B&W Companion with Goose Hitch ... what do you think? Thanks Frank
Old 01-31-2019, 06:58 PM   #23
I put timbrens on my old ram 1500 to get rid of the squat. worked well. look at the Anderson ultimate for your hitch if you have a short bed truck.
Congrats on the new camper. to get off the towing payload topic, I hope your rig shows up when promised, last spring there was much topic about lead times being extended.
Kimber45 is offline   Reply With Quote
Old 01-31-2019, 07:33 PM   #24
Indy500's Avatar
Wow, I just watched both videos. Congratulations. I have the 2018 model. But never seen the video how is made. I think maybe we got a good 5er. Crossing my fingers
Indy500 is offline   Reply With Quote
Old 01-31-2019, 07:39 PM   #25
I had Timbrens on a F-150.
They worked well.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 01-31-2019, 07:56 PM   #26
Canadian Member
The B&W Companion that connects via the gooseneck ball won’t allow you to use the turning pin box (Reese Revolution) as its intended. You’d have to lock it out and have it rotate at the pin/hitch connection like a conventional pin box. I opted to go with the B&W Patriot 18K that mounts on convention rails.
If you have the OEM pucks in your truck bed, then you can get a Companion hitch that will work with that and be able to take advantage of the Revolution pin box.
Old 01-31-2019, 08:03 PM   #27
frank4711's Avatar
Thanks ... did not know that ... I want to use the Turning Point as intended I will verify with my install guy, I have been working with him for 15 years he did all my work on my Lawn trailers ... Thanks Frank
Old 01-31-2019, 08:17 PM   #28
frank4711's Avatar
Bed is a 6.4 ... really want to use Turning Point as intended Amderson I have to lock out the wedge they said 8-12 weeks hope they are close .. Thanks Frank
Old 02-02-2019, 05:30 PM   #29
frank4711's Avatar
I expect to go with the Andersen I will keep the wedge locked out and add timbrens for the suspension .... I am close to max on payload and wand t save every lb ... I will change truck tires once I get some use out of these ... towing I should be about 900-1000 lbs under .... Thanks for all of the help and advice
Old 02-03-2019, 08:11 AM   #30
I didn't say anything about the hitch, but I towed with a Curt slider before I got the Andersen Ultimate II and I have a few observations.
1) It was extremely heavy. Even taken apart it was more than I wanted to handle, so I never removed it from the truck bed, thereby rendering the truck bed mostly unusable.
2) Even with the Ram short bed, I never slid it. Never had need to, so that was wasted capability.
3) I got the Andersen for the weight and it didn't disappoint. It's so light and easy to remove from the truck bed that I remove it whenever I'm not towing. And it's light enough to hang up on a couple wall hooks.
To sum it up, I would never go back to a conventional hitch.
Gotta go campin!
Old 02-03-2019, 11:05 AM   #31
frank4711's Avatar
Thanks ... do you have a rail or goose neck ball set up Frank
Old 02-04-2019, 10:10 AM   #32
I have the gooseneck ball setup.
I've had both rail and gooseneck and to me the ball connection is a lot easier to make and remove. Also the added bonus is that with the ball itself removed the truck bed is perfectly flat. Not that the standard rails are a big deal they just provide a hangup when loading some flat into the bed, like a piece of thin plywood.
Gotta go campin!
Old 02-04-2019, 10:25 AM   #33
I also prefer the passive Timbrens to airbags. They did the job for the rear end squat.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
chaps2018 is offline   Reply With Quote
Old 02-07-2019, 08:07 PM   #34
Enjoy the Rockwood!
We have a 2017 8299. We have 15 or so trips, probably 12,000 miles. TV is a GMC 2500 diesel, shortbed. Reese 18000 lb hitch. Love the turning radius with the Revolution pin box. Firestone airbags. Probably not required but do find some rural roads can get you in a wave like action that is not pleasant.
Replaced the tires over Christmas with Goodyears. Seems to ride much better. Get the camera setup. Big help on the road.
Enjoy!
dgardner888 is offline   Reply With Quote
Old 02-07-2019, 10:49 PM   #35
psaman's Avatar
Congratulations!! We picked up a 2898KS last November and love it. Unfortunately, we haven’t had a chance to take her on her maiden voyage yet.
2019 Rockwood Ultralight 2898KS
2018 Dodge Ram 2500 HD 6.7 Cummins
psaman is offline   Reply With Quote
Old 02-08-2019, 11:25 AM   #36
Nice
If the quality is as good on the rockwwod 5er as it is on the bumper pulls, you will have a great rig. I know our small 1809s has been trouble free, zero warranty issues since new in 2015. Our 5er on the other hand, not so lucky but it's a different brand. Love that layout, I need to go look at 1 myself now, time to trade both of our RV's in for one now we don't travel as much as we used to, that looks like the perfect size rig.
You may be pushing your Rams limits stock, maybe air bags would be a good investment along with a tuner and a cold air intake system, I tried towing a 33 ft bumper pull before we bought our 5er with a 1500 and while it was able to do the job, it was not a fun time, mileage was terrible, 4 to 5 mph, even with the updates I just mentioned, we bought a 3500 and never looked back. Better to have to much truck than not 3nough.
marcus morgan is offline   Reply With Quote
Old 02-08-2019, 05:50 PM   #37
frank4711's Avatar
Yes sir .... we like it and can't wait for it to get here. The Timbrens are here and will go on next week, we will be at max on payload with careful loading. Towing we will be about 1000lbs below max, will need to hit the scales when we get up and going. Tires will be next upgrade for truck and 5th and I am going to look into a camera, I think I will go with the B&W Patriot 18K and use the custom wedge from E-Trailer. Thanks Frank
rockwood
