Old 12-01-2023, 04:40 PM   #1
Newbee need to get my bearings!
Bought a 1999 38' Forest River Sandpiper TT. Going to get it tomorrow. About a 2 hour drive. The unit was originally purchased new and moved to the campsite, parked and never moved again. Should I be worried about repacking the bearings that have only100 miles on them?
WheelchairDon is offline   Reply With Quote
Old 12-01-2023, 04:48 PM   #2
Scoundrel
HangDiver's Avatar
I would. Some units come from the factory with very little grease to begin with.
Welcome to the forums!
EDIT: Also, trailer tires age out before they wear out. If it were me I'd replace them right away.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 12-01-2023, 05:44 PM   #3
Wow! Twenty four years since it's been moved?
I'd be worried about tires first, wheel bearings second, slides retracting, brakes and brake lights working and that's just to get it on the road.
Welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 12-01-2023, 06:23 PM   #4
Hook up and go, I wouldn't do it. I'd at least give everything a once over to be sure something isn't locked up or dragging and the brakes work nothing falling off. Tires are a crap shoot. I wouldn't haul it down the interstate at speed. I've seen it done many times but take some reasonable precautions before getting on the road.
2016 Sunseeker 3010 DS
If dogs don't go to heaven, when I die I want to go where they went.
Will Rogers
Sunseeker16 is online now   Reply With Quote
Old 12-01-2023, 06:49 PM   #5
Kanadian Kamper
kenandterry's Avatar
As everyone has mentioned……this unit needs an extensive wake up visit before even thinking of towing it home.
Imagine waking up Rip Van Winkle and asking him to run the Boston Marathon.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 12-01-2023, 08:52 PM   #6
Ouch! Tires 23 to 24 years old. I'm surprised they are holding air. I would replace the tires before putting the trailer on the road.
As to bearings and brakes, it is time to pull the hubs and do a good inspection. Likely lots of rust in and on the brake parts. Depending on the rust on the hubs where the brake linings contact, they may be able to be turned, depending on the rust pitting.
You will need to do a good inspection of the wiring associated with brakes, turn signal lights, and brake lights. Do a temporary fix on the system that doesn't work to make it road-worthy.
All of this depends on how far you have to travel. Even then, at a very conservative speed.
Bob
Bob K4TAX is online now   Reply With Quote
Old 12-02-2023, 12:15 PM   #7
I would be scared to tow that trailer for 2 hours with those tires!
Mokurt is offline   Reply With Quote
Old 12-02-2023, 02:04 PM   #8
doanshop's Avatar
How far are you going less than 100 miles get go ahead and tow it home then do Maintenace on it?
doanshop is offline   Reply With Quote
Old 12-02-2023, 05:43 PM   #9
PhilFromMaine's Avatar
It is official! The post has been hijacked! LOL
Referring to the OP, I would closely check the tires first before moving the trailer. IMO, the bearing inspection can weight until you get home. But the tires.......................
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
PhilFromMaine is offline   Reply With Quote
Old 12-02-2023, 08:19 PM   #10
Best of luck. You are going to need it.
Lots of things for you to check.
tomkatb is offline   Reply With Quote
Old 12-02-2023, 09:08 PM   #11
Georgia Rally Coordinator
aceinspp's Avatar
Hes got a lot to learn. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 12-02-2023, 10:41 PM   #12
YES and also get new tires before towing.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 12-03-2023, 08:09 AM   #13
Kanadian Kamper
No comment back from the OP since he first posted here.
We’ve offered our suggestions, it’s up to him now.
Ken and Terry
Old 12-03-2023, 11:13 AM   #14
Chuck_S's Avatar
Been less than 24 hours since this extremely naive topic was posted...
Would not surprise me if the trailer is untowable with rusted wheel bearings that may not allow the wheels to rotate and if they do not for long. The tires are absolute scrap and unsafe beyond a couple hundred feet.
Recommendation: Contact a mobile RV service and get the wheel bearings and spindles replaced along with the tires. You can buy new wheels with tires already mounted and install them in minutes. I've done it by myself in my driveway. Throw them in the back of the truck and take then to meet the mobile RV service.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 12-03-2023, 09:24 PM   #15
doanshop's Avatar
And poof! their gone!
Old 12-03-2023, 09:43 PM   #16
Scared him pretty good
All the gloom and doom about sheared spindles and blowout tires probably scared him off. Maybe could have been a bit gentler.
Larry
Larry-NC is offline   Reply With Quote
Old 12-04-2023, 08:42 AM   #17
I understand your point, but I would not pull it more than a couple of miles and make damn sure the tow vehicle can stop it without the aide of the trailer brakes.
Jim
East-West 34’ Alta 2850 KRL
2023 Expedition Platinum
jjscsix is offline   Reply With Quote
Old 12-04-2023, 10:47 AM   #18
And teach children how cute and cuddly bear cubs are. (Thank you, Disney).
Too bad the gloom and doom was not visited upon him BEFORE the purchase.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 200W CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 12-07-2023, 07:23 PM   #19
Tires and wheel bearings and anything that can be greased on that model.
jlynn721 is offline   Reply With Quote
Old 12-08-2023, 12:31 AM   #20
Novice Travel Trailer Guy
benchmarks's Avatar
Floor it!
Ah come on.....man-up. You only live once and you remember that rush you had when you were a teen. Feel that wind blowing through your hair....if you still have some?! Okay, I remember many bad choices I made. x2 on what everybody else said.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
bearings
