Originally Posted by tyler811
Would it be okay to close this off or is it cycling the air blowing the cold out by blowing the heat in?
I added underbelly heat to my camper. The only opening under my shower(I have a solid access panel) was a hole in the floor for the water/drain lines. If yours is the same I would not hesitate to cover it.
When the heat is on I get airflow through the opening. I left the cover on. I figure there are enough gaps elsewhere to let the air flow fine. Other drain lines and wiring have to go through the floor somewhere. I can feel air coming out of the seam from the shower base to the wall. It is not like these campers are made airtight.
I even taped up my underbelly cover to the frame to seal the gaps there. The only thing I can not seal is the push/pull tube opening through the frame. I still did put foil tape around the opening as the tube just bends it as needed. That way it seals up some. That keeps the wind from forcing cold air into the belly.
P.S. As long as you are mentioning the shower base, make sure the center is supported(I used solid insulation). Some people have posted of flex in their bases where they stand.
