Originally Posted by ScarlettD
Jayhawker that's pretty much exactly what I was thinking. I would really appreciate a couple more photos if you would please, even PM to me.
Really appreciated!
ScarlettD, here are the two pictures I have of the Blackstone griddle install.
I drilled out two rivets with an 1/8" bit, then increased the holes to 1/4". Centered the griddle and allowed some space behind the metal shield in the back. Some 1/4" x 20 bolts, washers, and nylon lock nuts. At first I used the one pound propane cylinders. When I got home I ordered the DOZYANT 1/4" RV quick connect adapter conversion fitting and use the quick connect hose that came with the TT .
I leave the cast iron griddle on the base when we travel and use a nylon strap to secure it.
