For avid boondockers filling the gray water tank often occurs sooner than the Black tank. One source of the extra water can be from showers.
If one is tent camping in the boondocks it's not unusual to hang a "Shower Bag" from a tree limb, let the sun heat it, then shower. Sometimes in the "alltogether" and sometimes wearing a swimsuit to keep from shocking the creatures in nature
No issues with the shower water being dumped right on the ground. However if it goes into a gray tank it seems to be a BIG problem if it's dumped on the ground.
How many use their outside showers in order to conserve space in the gray tank?
Ran across a simple, and inexpensive enclosure I might consider for my outside shower, of course taking into consideration where the water will be draining. Usually not a problem in desert like areas though.
Amazon has this for under $40:
Water can be easily hauled from many sources but waste water is often a bigger problem when a proper dump site might be a lot farther away then a water faucet.
Just wondering if others have gone a similar route when Boondocking.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
