Originally Posted by NavyLCDR
There must be something wrong with my trailer or garage wiring. I'm plugged into a 20 amp GFCI protected outlet in my garage. 30 amp to 15 amp doggone adapter plugged into garage outlet and 30 amp shore power cord plugged into the doggone.
I just camped for days in the trailer because my wife was COVID positive. Fridge was on AC (absorption type), water heater on electric, and A/C running, converter on. I had zero issues. No tripping breakers, no hot electrical connections.
A way to figure out why it worked so well is to conduct a load inventory. Make a list of the devices, figure out the amperage they pull, and figure out which ones run at the same time as others. What you see in that will tell you why it worked for you. There's no mystery to it- just tedium.
