11-01-2019, 12:52 PM
Pool Noodles on gutters: What keeps them in place?
Yes another winterizing question. I've read many a thread on winterizing & covers and every one says to cover sharp objects, like the gutter ends, with pool noodles, tennis balls, etc. Well what holds the noodles in place? I haven't tried yet but it seems to me that they would want to fall off, shift, or move as soon as you dragged the cover over them. I see you can buy tennis balls with a 10' strap between them, but I have a dozen or so pool noodles already. Free beats cheap.
Jim M.
https://www.amazon.com/Rescue-Gutter...s%2C161&sr=8-2
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
11-01-2019, 01:09 PM
You need to be careful when you put cover on, but once on the cover holds them in place.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-01-2019, 01:10 PM
I just got done putting on my 5th wheel cover for winter. I used (I think 1/2" ) pipe foam insulation cut to size. Fit tight but wrap some duct tape around it. $3 for much more than i needed, but can use at home too.
2018 RAM 2500 6.7 Diesel
2018 Rockwood 8299BS Diamond Package
Champion 3500W Wireless Remote Start Inverter Generator
11-01-2019, 01:21 PM
X2.
That's what my neighbor does. I've helped him the last two years.
He just slides them on the gutter extensions and then puts the cover down over. He did have to get up under the cover on one corner (using a step ladder) to reposition one that moved a little but once the cover was on, it held them tightly in position. His are only slightly longer than the gutter extension. (maybe 1/4")
11-01-2019, 03:20 PM
I cut an X in tennis balls. They don't move and won't fall off.
11-01-2019, 03:35 PM
Last couple of years I've wrapped the gutter ends with painters tape. Doesn't leave a glue residue in the Spring like duct tape can. I almost neglected to cover the slide-out awning gutters this year but the brains of the outfit (DW) was on-site to remind me.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
11-01-2019, 06:30 PM
Smart.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
11-02-2019, 04:28 AM
Great idea!
11-02-2019, 05:10 AM
I cut a smile into the tennis balls. Squeeze it open and slide into place. No movement when cover put on.
11-02-2019, 10:36 AM
Trailer Park Supervisor
Got 4 foam rubber baseballs at Dollar Store for 4 bucks. Cut an X into each one and jammed onto gutter like a clown nose. Held in place firmly, like hack522.
Yes, I drink the water!
11-02-2019, 02:54 PM
↑THIS↑ Smart!!!
2016 Salem 27RKSS
11-02-2019, 04:32 PM
What he said. This is exactly what I do and it keeps the cover from tearing on the sharp gutter spouts, even in high winds. Be generous with the length of the foam peices so they cover the gutter spouts completely. A cheap and effective solution.
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
11-02-2019, 04:45 PM
Dollar store is your friend, unless you have a need for really expensive balls!
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
11-02-2019, 05:38 PM
X2
2018 Rockwood 8244BS
2006 F250 6 speed
[SIGPIC]
11-02-2019, 06:51 PM
New TT Owner
We use tennis balls. Works much better than pool noodles.
11-03-2019, 08:42 AM
i us pool noddles that have the small holes, cut them them in 3 or 4 inch pieces and slide them on, they fit tight,(havent tried the balls yet) dont forget the rear bumper, reason is my cover was on and i found the cover started to wear a hole in it so it got plastic coffee cans and cut the top off so it would fit on the bumper ends, also the roof top antenna has those sharp antenna ends and pool noddles over them also
2019 FR Vibe 28RL
2018 Silverado 1500, Husky Centerline TS
3 Great Danes, 1 Weimaraner
Wonderful co-pilot
11-04-2019, 09:26 AM
Thanks to all that replied. Yes, it seems that once jammed on the gutters, the noodle seem firmly in place. I don't know if the gutter cut into the noodle, or the noodle crushed the gutter. We'll find out in a few months. Over all I used about 7 noodles. Most of those were to cover the two rails on the ladder.
Now that I have the cover on I wonder if it is fitting right. I measure my 2104s to be 19.5' long (back of spare tire to furthest point on box). So I order the ADCO tyvek cover for 18'-20' trailers (model 34840). The pictures show that the length seems fine, but the drop down the sides seems too short. I didn't even try to cover the spare tire because the cover barely reaches the bumper.
Does this look right? Our our MiniLites extra tall or sit high up? I sent ADCO a question but I figure I see what real people out there have noticed.
Jim M.
11-04-2019, 09:38 AM
I save a good section of an old discarded cover and cut a piece that fits over the propane tanks, jack and battery then simply tie it on with line.
TST Tire Monitors
2 100W solar panels
11-04-2019, 12:27 PM
That seems short, i have a Ofit cover new this year, TT is a Vibe 34ft, my cover hangs below the skirt and long enough to cover the tanks and spare tire, it was rated up to 34ft, fits nice and covers everthing
2019 FR Vibe 28RL
Wonderful co-pilot
11-04-2019, 12:33 PM
If I remember my instruction sheet said to cross the straps on the front and the rear. Might want to check yours and not tight
2019 FR Vibe 28RL
Wonderful co-pilot
