Old 01-25-2021, 03:35 PM   #1
portable fire pit that won't scorch grass or pavers
Hi!
We are going to an "RV Resort" that does not have firepits. One must bring one's own. They are very strict about not scorching their grass or pavers. If you scorch grass or pavers, there is a big fee to repair/replace. So...is there a portable firepit/fire ring that is elevated and will not scorch their grass or pavers and is easy enough to transport in a reasonable amount of space? thank you!!
cheers and happy camping.
2018 Coachmen Freelander 26RS
Parents, Grandparents, and 3-Dog Parents.
delphis is offline   Reply With Quote
Old 01-25-2021, 03:40 PM   #2
Trailer Park Supervisor
NJKris's Avatar
My Outland fire bowl does not even get warm beneath it. I use it on our RV plastic mat without any issues. Propane of course.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 01-25-2021, 03:47 PM   #3
Always Learning
Same as NJKris, I have a random propane firepit from Amazon (about $100) and it doesn't get hot underneath of it. We've sat ours on a plastic RV patio mat, too.
Same with friends of ours (who actually inspired me to try it).
Old 01-25-2021, 03:59 PM   #4
NJKris's Avatar
Nice to stay under awning with fire, isn't it? No sparks, no embers, like magic!
Old 01-25-2021, 04:13 PM   #5
I love mine as well, for the same reasons. As a bonus, my wife can sit by the fire with me without having the smoke chase her around.
Jfkmk is offline   Reply With Quote
Old 01-25-2021, 04:16 PM   #6
Every home center sells them. I use one on a patio once in awhile.
A fire pan is required on designated wild and scenic rivers. A steel pan designed to change old oil into would work. That is what we used on bare soil. In a fancy resort, you would want to support the pan with some bricks.
ppine is offline   Reply With Quote
Old 01-25-2021, 04:19 PM   #7
Part-Time Campground Host
cboss's Avatar
X2...We love our Outlander. We use it more and more rather than wood fires.
Craig & Cath
Days camped since 2015(retirement): 1680
cboss is offline   Reply With Quote
Old 01-25-2021, 04:21 PM   #8
Originally Posted by Jfkmk View Post
...As a bonus, my wife can sit by the fire with me without having the smoke chase her around.
This is so true!!!
Also, propane fire pits are usually allowed out west during fire bans. Usually.
Ours has little legs and to my knowledge has never affected the underlying surface. I guess one could get a small heatproof mat to be extra certain not to scorch their grass/pavers...
PodGeek is offline   Reply With Quote
Old 01-25-2021, 04:24 PM   #9
With the woods on fire due to neglect, fires are often not allowed in the West in the warmer months. I have thought of a propane fire bowl. I went on a trail ride once where a guy always had one. Odd at first, but then it seemed okay.
Old 01-25-2021, 04:27 PM   #10
Always Learning
Even nicer when we put it inside the Clam screen tent. With the sides up (with air gaps for safety), you can usually sit in there without a jacket in the coldest of temperatures that we've been in (down to the low 40s).
(Note: do this at your own risk- a burning tent is nothing to take lightly.)
Old 01-25-2021, 05:38 PM   #11
NJKris's Avatar
I just got the CLAM. Nice idea ependydad. In a normal tent I would never consider doing this, but the center of the CLAM roof is so high, I doubt it would even get warm. I got a pack of 3 sidewalls to block wind too, so even with 3 walls up, plenty of ventilation.
Old 01-25-2021, 06:13 PM   #12
Always Learning
Friends were concerned about the long-term effects on the tent material right at the top. Heat definitely collects up there. When seated, you could reach up above your head and feel the hotter air.
Like I said, we were comfortable with the risks - your mileage may vary.
Old 01-25-2021, 07:01 PM   #13
NJKris's Avatar
Well, you can always turn fire down a bit too. Another great propane fire advantage. I had mine on high under canopy. Without walls, I held arm over fire at about 6 feet and felt hardly any heat at all on a cold evening.
Old 01-25-2021, 11:03 PM   #14
Another option could be the Solo Stove Bonfire with Stand -
https://www.solostove.com/bonfire-plus-stand/
Skip12 is offline   Reply With Quote
Old 01-26-2021, 07:57 AM   #15
I like the look of the Outlander and size (19wide x11 tall), can you hook up direct to your motorhome so you don't need a separate propane tank? On their site it looks like the hose is a permanent connection and no mention of it. Thanks in advance
2017 Georgetown 31B3 CLASS A
-2008 28' Palomino Puma TT
-1996 33' Dutchment TT
Aulli17 is offline   Reply With Quote
Old 01-26-2021, 08:04 AM   #16
Retired Army MSG!
lazyjj's Avatar
I have the outlander as well and I simply change the hose to a quick connect hose if I want to run off the RV tanks. There is no regulator needed in the quick connect hookup to the RV as your RV regulator provides the needed flow of propane.
lazyjj is offline   Reply With Quote
Old 01-26-2021, 01:43 PM   #17
X2 on the solo bonfire if you really want some warmth from the unit.
Gerry & Linda Etzold
Annapolis, MD
TV - 2015 Ford F150, 3.5L Ecoboost, 3.55 gears, HD Tow
RV - 2018 Open Range 2804RK
getzold is offline   Reply With Quote
Old 01-26-2021, 01:55 PM   #18
Scubanut's Avatar
I use the 21 inch Outland portable fire bowl. I got mine at Costco Canada for $129 cdn. I also bought the natural gas conversion and use it at home as well. It only take a few minutes to convert it once you have done it a few times. It goes through a fair amount of propane so I like it for both uses. It doesn’t get that hot on the bottom so I doubt it would leave a mark on any surface.
Scubanut is offline   Reply With Quote
Old 01-26-2021, 02:07 PM   #19
Pop up Pit
When I want to save my propane and burn real wood. I use the pop up pit https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It is elevated and has a heat shield under it. Works great.
bigC is offline   Reply With Quote
Old 01-26-2021, 02:16 PM   #20
Currently, The Home Depot has a nice fire pit for $99, free shipping. It has a heat shield on the bottom, and comes with a cooking grate, too. https://www.homedepot.com/p/Hampton-...92RA/302563838
For a more portable fire pit, we have one with folding legs that stores in a bag. We have tested it extensively and it wont melt the asphalt underneath it. It comes in two sizes; I think ours is the 29 inch. https://www.amazon.com/dp/B004DN8IO0...ing=UTF8&psc=1
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
