Old 05-23-2020, 10:25 PM   #1
A2pfunk's Avatar
Probably a very dumb question... re: flushing the black tank
I see all kinds of posts on here about folks flushing and cleaning their blank tanks. It seems that a lot of time and effort goes into cleaning the tank that is meant to hold poop. I will admit, I have been sucked in to this in the past, myslef. I have dumped a bag of ice in there on occasion, and even done the calgon thing before. My only reason was that my sensors never seem to work. But then I realized that these sensors seem to be garbage and are questionable, at best, in all of my tanks.
Then I stepped back and wondered. WHY am I worried about the cleanliness of my sewage tank? There is not an odor issue. I tried to keep my kids from using the camper toilet for #2, but telling them not to poop in the camper only seems to make them suddenly have to poop. In the trailer. So it happens in there and there is never an odor issue. We dump when we leave the campground and everyting seems fine.
I have a septic tank at my house. I get it pumped every few years. I never worry about flushing it out. So what am I missing about the balck tank in campers?
2015 Coachmen Catalina 273TBS pulled by a 2019 F150 Platinum.
A2pfunk is offline   Reply With Quote
Old 05-23-2020, 10:44 PM   #2
If you don't have an odor from you're tank, you're probably doing the maintenance required. You've done the ice and the calgon thing. It's worth doing occasionally, but as long as you're treating it with chemicals and using enough water, I don't see why you should be concerned.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-24-2020, 12:44 AM   #3
CincyGus's Avatar
I agree with you.
In my opinion, 99% of black tank issues (Sensor issues, oder problems, toilet paper clogs or poop pyramids) can be solved by using more water than you think is necessary. My camper has 38 gallon black and gray tanks and 100 gallon fresh tank.
The first thing I do after dumping my tanks is go in and hold the toilet foot flush down until the sensor tells me I have 1/4 tank full. I would have to camp for 3 weeks straight to fill 39 gallons of black tank even if I had a couple of guests joining my wife and I. Plus the grays going to fill long before the black does.
So plenty of water for TP and Solids to break down in, a RV or septic tank safe TP and a a couple toilet tablets right off the bat and I don't have sensor, order or TP or Pyramid issues.
I hook a hose to the black tank flush about once a quarter at most and let it spray the walls and whatever it hits in the tank. Never had issues using this method on the old camper and it didn't have a black tank flush.
Operator error most of the time for black tank issues is my opinion. Maybe I'll jinx myself but 10-11 years in and haven't yet.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 05-24-2020, 01:05 AM   #4
Hclarkx's Avatar
I agree also. It took me a couple of years to figure out I don't need the sensors and don't need to let a flexible hose flop around in there when we get home. I do add some enzyme stuff after each dump. Even if I flush with the overhead fan running I smell nothing.
Early on I worried that I might fill the black tank during our two-week boondocks (two adults). Then I looked at the fresh water we use and subtracted the grey and galley tanks (which do fill up), and there's not enough left to get the black tank over about 75%. In fact, when the galley waste tank fills up, we start dumping dish water into the black tank.
The grey tank sensors still work for the most part. The galley tank sensors turn on prematurely except the full one seems to only turn on when the tank is very close to full.
2020 GMC Denali 2500HD Crew 4X4 Gas 6.6L
2015 30' 8280WS Rockwood Ultra Lite - lifted 3"
Solar plus LiFePO4 and 12V fridge.
Hclarkx is offline   Reply With Quote
Old 05-24-2020, 02:35 AM   #5
I kinda laugh at people who think it has to be spotless. The bag of ice people crack me up the most....well maybe the people that never poop in their toilet.
babock is offline   Reply With Quote
Old 05-24-2020, 06:29 AM   #6
Member: Old Man Club
RockDodger's Avatar
Five gallons of water and a capful of Rid-X will keep the solids under control. I never worry about it.
"Walk softly...and carry a lot of tools!"
2016 Ford F250 Super Duty Crew Cab, 4x4
2021 Palomino Puma 27RLSS
RockDodger is offline   Reply With Quote
Old 05-24-2020, 07:47 AM   #7
Yahoo , I finally got people that agree with me . If it ain't a problem do not make it one ! I have also found that a lot of black tank problems can be cured by going for a drive which will agitate the contents and cure some clogs .
wanderingbob is offline   Reply With Quote
Old 05-24-2020, 08:02 AM   #8
jeff64's Avatar
I've carried 2 5 gal. cans with ever since the first pup. Dump both through the toilet as fast as you can fill it and push the pedal. You'd be amazed at what that slug of water going into the tank dislodges and pushes out. Great procedure at end of the season or if you aren't going to use it for a while
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 05-24-2020, 08:16 AM   #9
Canadian Member
You can’t think of the black tank as a septic tank, it’s a holding tank. You dump it relying on gravity, not pump/suck out the contents.
The sensors may never work 100% but I don’t understand why it’s a big deal to flush the tank (using the factory-installed flusher) and add something of your choice to break down the solids and control odour. I do the dumping and flushing outside while my DW is inside preparing the Geo Method mix and dumping it into the toilet. It adds maybe 5 minutes to the whole dumping process. If I’m dumping at a dump station and there’s a line up we skip the flush that time. No sweat.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 05-24-2020, 09:04 AM   #10
I agree that it's not necessary to use the black tank flush if you otherwise maintain it properly and travel. I think having a few gallons sloshing around really helps break things up.
We used to leave our tt at a seasonal site where I used the flush for 15 minutes at the end of each visit.
I see nothing wrong with using it otherwise...just limited value. Probably wise to keep the sprayer nozzle clean and functional for the time you really need it.
Skip12 is offline   Reply With Quote
Old 05-24-2020, 09:04 AM   #11
But why go to the dump station when you can do all that right on your site? See so many people lined up at station when it’s time to go. I’ve asked people who are in line and they all pretty much say same thing.... “ that’s what everyone does when it’s time to leave”. I don’t get it, but I guess if they don’t mind waiting for a while in line, it’s none of my business. Lol
dodgemark is offline   Reply With Quote
Old 05-24-2020, 09:08 AM   #12
Mr. Dan's Avatar
You can’t “do all that right on your site” if you don’t have a full hook up (sewer) site.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 05-24-2020, 09:13 AM   #13
nomad297's Avatar
You can if you have a portable holding tank.
Bruce
Old 05-24-2020, 09:15 AM   #14
Mr. Dan's Avatar
Bruce
As I read this forum, it seems most people won’t put black tank contents in their “stool bus”.
Old 05-24-2020, 10:40 AM   #15
Bruce
That doesnt seem like a solution if you're goal is to reduce time spent at the dump station on a busy departure day!
Old 05-24-2020, 11:04 AM   #16
Usually Confused Member
emm-dee's Avatar
The black tank flush fitting is not much good for anything except putting water into the tank. Only seven really small streams of water so it’s not going to cover much.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 05-24-2020, 11:06 AM   #17
I have a macerator pump and a hose that reaches a sewer clean out. If my next stop is home, I skip the line.
Old 05-24-2020, 12:34 PM   #18
Tom48's Avatar
DITTO
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 05-24-2020, 01:11 PM   #19
Canadian Member
About half of our camping is at Provincial Parks where they only offer electric-only or non-electric (unserviced) sites. So in those campgrounds we have to go to the dump station. We tend to book so we can depart on a weekday to avoid the long lineups on Sunday. Our fifth wheel is too big to fit in our suburban home’s driveway so we can’t empty the tanks at home.
Old 05-24-2020, 01:42 PM   #20
My black tank flush goes in right above the black tank drain, so it doesn't do much in the way of a "flush."
So I've never bothered to use it.
Name:	Black tank flush connection .jpg
2011 Traverse LT, 3.6L, FWD
black, black tank, flush, tank
