Old 03-01-2020, 05:57 PM   #1
Propane
Hello. Can so.e o e tell me a step I may be missing? We are new to RV world. Have a 2011 berkshire forest river. We turned on the 1/2 full propane tank but nothing is flowing to the stove. What am I missing
Ldyatfcop is offline   Reply With Quote
Old 03-01-2020, 06:19 PM   #2
Is it flowing to other appliances? Water heater, fridge or furnace?
Mark & Susan
Former MBS 24R and 2401W Owners
Just recalibrating our camping set-up for now!
barnbnb is offline   Reply With Quote
Old 03-01-2020, 06:21 PM   #3
coney's Avatar
Sometimes you just have to open the valve slowly
Central Jersey
2017 Nissan Pathfinder SL
2019 Shamrock 19
coney is offline   Reply With Quote
Old 03-01-2020, 06:21 PM   #4
Brother Les's Avatar
may be air in the lines. It will take a few minutes with the burner on to purge the air out. Use the lighter every few seconds for when the gas gets to the burner. You should also be able to smell the propane when it starts to flow at the burner.
Brother Les
Old 03-01-2020, 06:24 PM   #5
Flybob's Avatar
How long did you wait? If lines were empty, it may take a minute or so to purge the air.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-01-2020, 06:25 PM   #6
And did you remember to turn the LP tank valve the proper direction?
Mark & Susan
Old 03-01-2020, 06:29 PM   #7
Does not appear to be.
Old 03-01-2020, 06:29 PM   #8
X 2 several of my rv stoves have been finicky and it takes several minutes.
Kimber45 is offline   Reply With Quote
Old 03-01-2020, 06:33 PM   #9
Thank you everyone. It is not flowing to any appliances..we waited over ten minutes each time. I put in a new CO and propane alarm. Iurs had expired. The new one only has 2 wires where as the old one had 4. We did however co next all wires and still nothing. Not even a smell of propane
Old 03-01-2020, 06:37 PM   #10
The first thing I'd do is try a different tank. I had one where the OPD malfunctioned and shut off the gas.
Mark & Susan
Old 03-01-2020, 06:39 PM   #11
I can not use another tank. This one is huge and installed directly on the rig
Old 03-01-2020, 06:40 PM   #12
Is there a way to use a smaller one? I'm not sure where to install a newer smaller one
Old 03-01-2020, 06:40 PM   #13
wmtire's Avatar
This replacement alarm could be the problem. The alarm cuts off propane flow in some motorhomes. Hold on let me get you more information
2011 Flagstaff 831 RLBSS
I can't stand it when people get well known sayings wrong. I mean, it's not rocket surgery.
Old 03-01-2020, 06:42 PM   #14
Flybob's Avatar
OK the issue is the new alarm. The old one was connected to a solenoid that shut off the propane if it was not operating or detected propane, You need one with 4 wires that is designed for a system with a solenoid
TST Tire Monitors
2 100W solar panels
Old 03-01-2020, 06:46 PM   #15
Awesome. Thank you
Old 03-01-2020, 06:47 PM   #16
But they dont make them from what we are told???
Old 03-01-2020, 06:49 PM   #17
Will see if someone at the dealer can tell us where to get it. Thank you all very much. I love this place
Old 03-01-2020, 06:51 PM   #18
wmtire's Avatar
Here is a previous link I was searching for:
https://www.forestriverforums.com/fo...ml#post1439621
Old 03-01-2020, 06:53 PM   #19
You can unscrew the regulator assembly from the tank and it will attach directly to a BBQ tank. That's what I had to do on mine until I got the tank fixed.
Also, are you relying on an electronic or mechanical gage to read the amount in the tank?
Mine was showing full, even tho I knew it wasn't. And when the OPD failed, I could not add LP to the tank, either.
Mark & Susan
Old 03-01-2020, 06:55 PM   #20
Thank you for the link
propane
