One question. Does the LP tank have a round dial type mechanical gauge held on by 4 screws? If they are like the ones on the 500+ gallon tanks for houses and farms the gauge works by a magnet mounted on the float mechanism. Sometimes the bouncing can cause the magnet to fall off. Other times the needle will get stuck, preventing it from moving in conjunction with the float. The next time you have a propane truck fill the tank, ask the guy to change the external dial part. If it don't work then the problem is with the float mechanism inside the tank. To change the float the tank will have to be empty.
Richard & Jill
