Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-26-2020, 09:58 AM   #21
Just as confused as you
Scrapper's Avatar
Originally Posted by thepeddler View Post
Scrapper: Thanks, you saved me a phone call. I'll have to find a close "Farmers Coop" and give them a call.
Give these a try, both have refill & delivery of forklift LP tanks so they will have the equipment needed. The second has 2 locations around Lincoln, I don't see a Farmers Coop listed. I don't know how much anyone charges for the service so if you want to get by cheap use the gas up as others have suggested.
Lee's Propane Service Inc
Matheson
Richard & Jill
Old 10-26-2020, 11:18 AM   #22
Propane Tank Knob Problem
Scrapper, thanks again. Matheson and Lee's does not do that type of repair. The only other possibility is Great Plains Propane Service in Ashland.
thepeddler is offline   Reply With Quote
Old 10-26-2020, 12:13 PM   #23
Have you actually removed the knob to see if maybe a stripped knob is all you have? If it is, you don't need a gas company to change it out.
Gotta go campin!
Old 10-26-2020, 03:50 PM   #24
Bama Rambler, been TOO COLD here in Nebraska to go out and see if I can get the knob off. Possibly Wednesday or Thursday I can do this.
Old 10-27-2020, 05:14 PM   #25
Assuming the knob to shaft interface is stripped out (e.g. the spline is bad or the square-socket handle is cracked), you could remove the handle and use pliers or vice grips to open the valve and use the propane supply to allow swapping out the valve. If it's a square-socket handle, those are easy to replace. If it's a stripped spline on the valve, most valves CAN be disassembled and the shaft replaced, but that's when I'd just go for a new valve.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 10-27-2020, 05:25 PM   #26
Jim, thanks. I'll keep this in mind when I take the knob off once the weather gets a little higher here in Nebraska.
Old 10-27-2020, 05:56 PM   #27
SlowrideHD's Avatar
Why are you concerned about it? I know motorhome owners that haven't shut their propane tank valve in years. I would think you would just use it up as you need to and worry about it when the tank gets empty. Would save a lot of trouble.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 10-27-2020, 08:27 PM   #28
SlowrideHD, yah, I may have to do that. I just want some piece of mind knowing the knob is off or on. We have had a number of nights in the MH with the knob that way.
Old 10-30-2020, 08:48 AM   #29
Who shot who in the parlor...
This is like a murder mystery. Who is the killer??
Please post a picture of the "spline" shaft so I can go to sleep!
Central Texas
2000 Bloomer Toy Hauler
2000 FLHP
1958 DW
djglover7 is offline   Reply With Quote
Old 10-31-2020, 10:06 PM   #30
Scrapper's Avatar
There is a picture of the spline shaft in post #4 by 5picker.
Richard & Jill
Old 11-01-2020, 08:09 AM   #31
Mystery not solved
"Here's an image of a typical propane tank knob..."
Need the real thing.
Central Texas
2000 FLHP
1958 DW
Old 11-03-2020, 10:54 PM   #32
Just wanted to say thanks to everyone on this forum who commented and offered suggestions. This forum really puts out the help when you need info. The weather here in Nebraska gave us a break, and I was able to get my Coachmen Freelander to a farm propane supplier. He tried a knob that might fit; it didn't. He fetched his box of spare knobs and found one that worked turning on and off. He checked the connections making sure there were no leaks. Flame came on inside the coach also. He worked on this for about a half hour; They only charged me $15.00. He said knobs for a motorhome could cost $55.00. So again thanks.
Old 11-03-2020, 11:41 PM   #33
Thanks for reporting back. It's always nice to hear that a problem was solved.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 11-04-2020, 08:12 AM   #34
Yes, thanks much for coming back and letting us know that all it took was a new knob to fix it. Glad you found someone that knew what they were doing.
Gotta go campin!
Old 11-04-2020, 07:47 PM   #35
Wonderful news!
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=19
propane, tank
