08-06-2024, 03:06 PM
Protecting new asphalt drive
I just replaced my asphalt driveway. The asphalt was 3” and compacted to 2” and placed on compacted gravel. The house was built in 1955 so it’s pretty stabilized. My question is for those experienced in parking their small, 3,800 lb trailer, on their asphalt driveway, should I be concerned about leaving indentations in the asphalt from the tires? The trailer is single axle and the jacks are manual screw down. I’ll be parking the trailer at home just during the summer months while we come and go on our trips. During the Winter it will be stored elsewhere. If plywood, what size might be best. I’ll need to keep the tires pretty close to the edge to allow space for car going in and out of garage.
As always, thanks in advance
08-06-2024, 03:31 PM
Kanadian Kamper
Virgin asphalt is always prone to indentations, and especially if exposed to hot sunlight. The minimum protection I would use for your 3 points of contact……
Go to the lumber store, purchase a plank of 2” x 12” (usually sold in 8’ lengths)
Have them make three 2’ cuts, and you’ll have four sections.
In your case, you should have enough protection for your 3 points of contact, and you’ll have a spare.
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
08-06-2024, 04:12 PM
I would place 24" to 30 inch plywood squares under every contact point for at least a few years. after a few years the asphalt stiffens up, every time I move the trailer I flip the ply over to keep it from warping. DR
08-06-2024, 04:23 PM
This is what I use. I once neglected to use the 2x12s and the tires sunk into the asphalt and this was in Maine. Granted, it was one of those rare days the temp hit 90 degrees.
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
08-06-2024, 04:39 PM
X2!! on the 2x12s
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
08-07-2024, 01:09 PM
A question as a point of interest: Where do you park the TV?
2016 Salem 27RKSS
08-07-2024, 01:27 PM
Trailer Park Supervisor
x3 on the 2x12s. I used smaller pieces of wood initially on my fresh paved driveway, and my lightweight single axle camper left depressions in asphalt. Been fine since I used longer and bigger boards. Plus they are good targets when backing into my spot so I know everything is lined up, especially when tow vehicle is at an angle backing in and you can only see the driver's side.
Yes, I drink the water!
08-07-2024, 02:24 PM
Thanks everybody for the suggestions. I’ll be doing the 2x12’s cut to 2’. For the question as to where I park the tv, it’s in the garage.
2021 Salem fsx 167rbk
2019 Kia Sorento ex v6 awd
08-07-2024, 03:14 PM
If I were you I would buy two 8' planks and cut then in half or one 12' cut into 3 pcs.
I think 4 ft planks would be better than 2 ft.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
08-07-2024, 03:44 PM
For the low side of the trailer, you might try to find some plate steel for under the tire so you don't need to raise the low side that much more to get it level side-to-side
08-07-2024, 04:17 PM
Agreed. So much easier than trying to target a small bullseye parking it. Makes it especially easy to have some leeway to back onto my Anderson leveling wedge on top of the plank as I frequently pre-chill fridge in driveway and it has to be fairly level (absorption fridge).
08-07-2024, 07:04 PM
If you plan to get 2" x 12" x 8', then have them saw the pieces on a 45 degree angle. Makes for the same number of cuts and makes it easier to get the tires on the blocks.
Bob
08-07-2024, 10:17 PM
Is there any way that you can park off the driveway through the summer?
Any heavy object that isn't being moved on a regular basis can and will make indents on new asphalt, especially for the first few months, and especially in the hot weather. If not, I second (tenth?) the recommendation of 2x12s under the tires.
