Originally Posted by 05CrewDually
The endorsements you're referring to are for commercial purposes NOT personal use, in this case pickup and R/V camp trailer. You are not exempt.
I am. My Class A also covers RV towing. Better read the fine print.
Additionally, Michigan does not recognize triple trailers at all no matter what configuration even though I do hold a Michigan triples endorsement. I run breakup doubles here. A trains and B trains. The A train is a set of doubles with a pintle type connection and a B train is the lead has a stinger with a fifth wheel attached that you can actually back up if you know what you are doing.
An A train would be similar to say a set of UPS doubles with a converter dolly for the rear trailer with a pintle hook on the lead that the dolly hooks to (very similar to having a ball hitch on your rear bumper).
