Old 05-09-2020, 09:48 AM   #1
Quarantine Storage Questions
My DW and I are Covid-19 high risk x4, so we're probably going to keep our 5er in the driveway until the infection rates drop a lot or a good vaccine is available. The last time we moved our rig was late February when it was in the shop for annual maintenance.
So, the questions: 1) Is it safe to leave last year's fresh water antifreeze in the system until next camping season if it comes to that, or should I flush it and re-winterize this year? 2) I've ordered tire covers which I've never used previously because the trailer is usually on the road a lot. Are there any other tire issues I should consider since its possible it will be a year between trips? 3) are there any other issues to be aware of for long-term storage?
Please keep your suggestions to trailer-related topics. I am aware some may think I'm being over cautious, and you are certainly entitled to your opinions. I love being on the road and I get a knot in my stomach every time I glance at my parked trailer. But the level of risk one is willing to take is a matter of personal choice, and I'd appreciate it of responders respect our decision.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 05-09-2020, 09:58 AM   #2
DrLewie covering the tires is a good idea but the tires can still get dry rot and look in good shape. Tires need to be driven on to keep them alive and well. A technical thing you can read up on if you wish. So hook up that trailer and go for a drive and come home. PIA maybe but good for the tires.
Dennis878 is offline   Reply With Quote
Old 05-09-2020, 10:01 AM   #3
Chris Pastuzyn's Avatar
I believe the antifreeze should be fine,As for the tires,covering them can't hurt to keep the sun from beating on them .
Chris Pastuzyn is offline   Reply With Quote
Old 05-12-2020, 08:20 AM   #4
Funengineer's Avatar
DrLewie
I think your water system should be fine with the RV antifreeze while in storage. The factory sends them to the dealers that way and they sit on dealers lots for months if not longer. I also subscribe to the use of tire covers too. If your fiver actually sits in your driveway I would definitely keep it plugged in to maintain your battery(s) or remove them and bring them home to trickle charge if the fiver is off site.
I’m sorry that you are both at risk as we are. Thank you for protecting me and others. We will all get through this just not soon enough. Stay home, be kind and stay safe.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
Funengineer is offline   Reply With Quote
Old 05-12-2020, 06:31 PM   #5
Moosey1's Avatar
Take it out for a ride per Dennis878 for a good 30 minutes of driving All that motion will help the tanks and the tires
Moosey1 is offline   Reply With Quote
Old 05-12-2020, 07:04 PM   #6
Kanadian Kamper
kenandterry's Avatar
Having endured several loooooooong Canadian winters being parked for inhumane periods of time......
Covered tires for up to 6 months have presented no severe issues so far.
What is important is what the tires are parked on.
Grass, mud, dirt......all bad.
Asphalt.....I’ve read as being bad, because of oils and such leaching into the rubber of your tires.
Hardwood 2x12” boards is good.....tires completely ON the board.
Concrete I’ve read is good.....no leaching.
Good sized gravel is best because it allows good air circulation and drainage.
RV antifreeze life expectancy.......not sure on that one.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
kenandterry is online now   Reply With Quote
Old 05-12-2020, 07:23 PM   #7
Antifreeze last for many years. Follow the road advise of those above.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equalizer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
storage
