Old 08-17-2019, 09:15 AM   #81
Originally Posted by Ruggybuggy View Post
Correct me if I'm wrong but the Frontier was rated for 6,500lbs max towing. The issue really isn't what it can tow but what the payload of the truck is. It's easy to get over the payload on most mid size truck if you fill them with people and gear them add the tongue weight
Our 4wd Frontier had a max tow rating of 6,300#, which was easily found on their website. What was not so well-advertised was that it had a max trailer frontal area of 60 sq. ft. That could only be found by carefully reading the owner's manual. Since our Mini Light 2109S had a relatively flat front of 64 sq. ft., we had significant problems towing on Interstates and in headwinds. You wouldn't think that small difference in area would be significant, but it was.
That didn't prevent us towing it for 27,000 miles with the Frontier and a great Reese cam-type weight distribution-sway control hitch, including an Alaska trip. But too much of that mileage was stressful, if not downright white-knuckled.
fanrgs is offline   Reply With Quote
Old 08-17-2019, 10:49 AM   #82
Originally Posted by SandFox View Post
So after all this craziness, I upgraded to the titian xd. Gotta say, I'm amazed. Many more adventures to come! Thank everyone for the insight.
Hopefully, not the one with the diesel engine.
babock is offline   Reply With Quote
Old 08-17-2019, 03:21 PM   #83
What was the issue with the diesel?
Ruggybuggy is offline   Reply With Quote
Old 08-17-2019, 04:01 PM   #84
Nissan and Cummins are getting a divorce.
Not many people chose the diesel. It will be a rare item.
tomkatb is offline   Reply With Quote
