Old 08-07-2020, 07:37 AM   #1
Question raising tt for storage
hi folks.what is the general thinking on raising a t.t. for storage? I have a 2021 rockwood mini lite 2104s with the torflex axles. I was thinking of jacking it up and blocking the axles close to the frame to remove the weight on the tires.
is there any benefit to this,or would I be damaging the unit?
mods to date; removed the caps from the low point water line drains,replaced with angle stop valves,removed oem water filter to use inline filter,made a nifty spare tire bar/bracket which mounts between frame rails near the front.
as always,thank you for your input.
pamike is offline   Reply With Quote
Old 08-07-2020, 08:59 AM   #2
You can buy tire cushions for vehicles that sit "like classic cars" Google it . not cheap but very easy to use. Radial tires dont flatten like bias tires. Try Summitt racing , lmc truck, search around you will find them.
Thomas ho is offline   Reply With Quote
storage
