Old 05-25-2020, 05:34 PM   #1
Replace LED TV in 2009 Flagstaff
I want to replace my 18 in. LED TV in my 2009 Flagstaff and don't know what kind of TV to get. Any suggestions?
babyfufinu is offline   Reply With Quote
Old 05-25-2020, 05:45 PM   #2
rsdata's Avatar
any kind of TV that you want... Walmart, and big box store
a popular replacement size is 32 inch if you have that much room
biggest concern is that you have at least the same input and outputs in the TV as the old one does... adapter types and numbers change in different makes and models and if you do not have the right inputs/outputs the new TV might not work that same as your old one... as far as hooking up to your existing stereo and speakers
take a phone pic of those inputs and outputs on old tv set with you when you look at new ones... have a knowledgeable salesman at a place like Best Buy help you if that confuses you as to inputs/outputs
2014 Shamrock 183
Old 05-25-2020, 06:04 PM   #3
bikendan's Avatar
It would help to know if it's 12v or 110v.
If it's 110 AC, then any tv will work.
If it's 12v, then you jave way less choices.
You should already know which one it is.
Old 05-25-2020, 07:56 PM   #4
It is a 12v.
Old 05-25-2020, 08:08 PM   #5
rsdata's Avatar
If you only stay in places without 120VAC to plug into, then look for another 12V tv replacement. However if you stay in places that offer a plug in to shore power (120VAC) then I would not worry about it. You will have a bigger selection at a lower cost then having to get a 12V TV only...
look at amazon for 12 V LED TV for some suggestions.
2014 Shamrock 183
Old 05-25-2020, 09:30 PM   #6
bikendan's Avatar
It is a 12v.
Well, that limits your choices, plus they cost more than the same size 110v tv.
Personally I wouldn't have one. I prefer a much cheaper 110v tv and use an inverter.
Old 05-26-2020, 01:40 PM   #7
Long Leaf Piners's Avatar
We had a really nice 40" Visio in the living room of our fith wheel and it began to fail. Our Flagstaff team, at Goshen, replaced it with a Furion. This Furion has worked well for us, as they are made to go down the road. We do still have a 21" Visio, in our bedroom and that has continued to work well. So, size of unit may make a difference about ability to withstand the vibrations and bumps of going down the road.
2014 8528 IKWS
Ford F-250 Diesel
Cricket the Cairn and Sally the Terrier Muppet Mix
Long Leaf Piners is offline   Reply With Quote
flagstaff, led
