Old 11-29-2017, 10:19 AM   #1
Replacing Skylights - Screw Type Needed
I am going to be replacing both the living area and bathroom skylights. As I have read about the replacement on line I have never seen any description for the screw type. One site said to reuse screws and I don't want to do that. However I want to have the new screws already purchased so available when I install the skylights. So, what type of screw should be used? What size? What length? Appreciate any feedback.
dlewand53 is offline   Reply With Quote
Old 11-29-2017, 10:51 AM   #2
Likely a 3/4 inch long square head. If your replacing them then get SS pan head screws in either 3/4 or 1 inch long.
donniedu is offline   Reply With Quote
Old 11-29-2017, 11:21 AM   #3
Restcure's Avatar
I suggest you count all of the screws you're going to need, then remove one from the skylight and take it to your local hardware store for a match.
I'm curious... is there a particular reason you don't want to reuse the screws?
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 11-29-2017, 12:09 PM   #4
My experience has been rusty or the head snaps off when put in again. Want to be sure I am using a non rusting type of screw.
Old 11-29-2017, 01:35 PM   #5
Petersb's Avatar
I would definitely use stainless screws they are not supposed to rust
Petersb is offline   Reply With Quote
Old 11-29-2017, 02:39 PM   #6
mudman2's Avatar
Skylights
Just a thought. U may want to forgoe screws and caulk it down and then Eternabond which you’ll probably have to do down the line anyway. I have a aframe with skylights where one has a crack in the corner of the flange. I’m going to Eternabond it an hope it works.
Everybody says it’s the greatest thing since sliced bread.
We’ll see.
mudman2 is offline   Reply With Quote
Old 11-29-2017, 05:32 PM   #7
I agree that removing a single screw for a sample would be worth the effort. Plus you may discover that the screws are in great condition. But, they may well be aluminum...not steel. If so, be sure to use a square drive bit rather than Phillips, or you may strip the head. Many RV screws are both Phillips and square drive, which makes it much easier for the assemblers who are using power tools to drive screws with a square drive bit.
If you remove a sample, some regular household caulk will seal the hole temporarily.
If you buy new screws, definitely replace with stainless. Stainless is compatible with aluminum (skylight frame, framing structure, etc.), and they are both stronger and won't corrode.
If any of the screw holes are enlarged, the new screws may not hold well. In that case, or if you have issues with screws vibrating loose on washboard roads, etc., I recommend using Gorilla Glue in the holes and on the threads. This glue bonds to metal and many other materials, and it will thoroughly seal the hole to prevent water chasing down the screw threads in the event of a caulking failure. Bear in mind, however, that Gorilla Glue is STRONG. It might be very hard to remove the screws next time you replace the skylights. Alternatively, you can buy one size larger stainless screws, e.g. #8 instead of #6 and so on.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
jimmoore13 is offline   Reply With Quote
Old 11-29-2017, 06:02 PM   #8
NMWildcat's Avatar
When I replaced all my skylights, the new screw holes didn't line up and there were more required for the new ones. They were all 1" self tappers. Get some skylight caulk ( yes they make it) and use it around the opening before placing. Then screw it in firmly, but not enough to distort plastic, then eternabond it. Hardest part is cleaning up the old caulk
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 11-29-2017, 11:04 PM   #9
Fkrel's Avatar
When I replaced the roof on my class A I replaced the skylight I had to drill new holes in the skylight so I spaced them so it was making a new hole in the motorhome also and put buytal tape under the skylight edge after mounting I used dicor self leveling caulk it came out great. Here is a place I orderd a lexan skylight lexan is alot tougher than the usual plexi skylights. RV Skylights, Square, Rectangular & Round.
1972 cree trailer
1978 mallard trailer
1986 Itasca class c
1994 coachman class A
2005 3100SS sunseeker class c
Fkrel is offline   Reply With Quote
Old 11-29-2017, 11:53 PM   #10
MacGumbo's Avatar
Actually they can rust, albeit very slow on their own and usually you can clean it off, hence the "stainless" label.
2020 Grand Design Reflection 240 RL
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
MacGumbo is offline   Reply With Quote
light, skylight
