Old 06-08-2017, 06:51 AM   #1
Residential frig?
So, thinking about getting a TT, 50 amp with a residential frig.
It is my understanding that it will not run off of propane gas.
So, how does it work when you are driving? Or does it?
bmcevers_13 is offline   Reply With Quote
Old 06-08-2017, 06:54 AM   #2
BessieHunter's Avatar
Our frig runs off a pass-through inverter that you turn on prior to unhooking shore power. The inverter runs off the 12 volt system of the trailer.
BessieHunter is offline   Reply With Quote
Old 06-08-2017, 07:00 AM   #3
Your TV alternator should keep the batteries up to charge (or close) when driving and while the inverter is pulling current from the batteries to run the 120 volt reefer. Depending on the model of reefer it will average about 8 amps continuously or less and the TV charge line, if well installed, should be able to keep up with that or not fall that far behind.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 06-08-2017, 07:14 AM   #4
Make sure you have an inverter switch so you can run fridge while in tow.
jeffandrews55 is offline   Reply With Quote
Old 06-08-2017, 12:18 PM   #5
agreed. it will run off the batteries and tow vehicle via the inverter while travelling. but to bigger issue has to do with running the refrigerator while not hooked up to shore power (if that is what you intend to do).
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
