Running frig on road
Many folks run the refrig on propane while underway without problem. Before using propane for my refrig, or heater, I always turn on a stove burner to first make sure I have propane flowing and there are no problems elsewhere (e.g., a regulator issue). Don't know what type RV you have but am assuming you have a Dometic or Norcold. One thing to understand is that while these refrigerators run on propane or 110V, they still require 12V to operate the control system. If your 12V cutoff switch is off the refrig won't work (assuming you have a cutoff).
Sue and John
29RLBS Wildcat
2008 F350 Lariat
