View Poll Results: Is it worth the money to upgrade leveling jacks?
Yes
0 |
0% |
No
3 |
50.00% |
Depends
3 |
50.00% |
Always better to upgrade.
0 |
0% |
03-20-2021, 06:02 PM
Rusty Stabilizing Jacks
Hi all. I'm new to the forum. We bought a new, 2020 Flagstaff Microlite 25 bds in the fall of 2019 and really like it except for one thing. I noticed that the paint on the stabilizing jacks was flaking off in big flakes within six months of purchase. At that time the trailer had just over 1,000 miles on it, never in winter. In spring I went back to the dealer to complain. It's a great dealership and I've had great service. They told me, however, that they have made multiple claims to Forest River on just that issue and all have been turned down because it's an "environmental issue". Okay, I know that rust over time is an environmental issue but paint literally falling off in mild weather within six months is not due to environment but due to improper prep and painting. Apparently, Forest River believes that they can source cheap, improperly painted jacks because any problems can be dismissed as "environmental". I know they know better! Sad.
So, has anyone had experience with aftermarket jacks? I see some on Amazon that are heavier gauge with 7,500 lb capacity but none mention paint finish at all. Mine make my new trailer look junky so I don't want to go through this again. I know there are those of you out there with experience and I'd appreciate any advice.
Tom
03-20-2021, 06:58 PM
Trailer Park Supervisor
Mine look pretty shabby too. It seems to be the norm. But they work fine. I plan on unbolting them and using a power tool to knock off old paint and rust and give them a good painting with Rustoleum.
Yes, I drink the water!
03-20-2021, 08:47 PM
I was able to get FR to replace mine within the first year but I had two major manufacturing failures that they fixed at the factory service center so I think they did that to appease me. They were better quality with better powder coating and plating of the threaded rod and trunnions but in less than a year all the powder coated parts are showing signs of rusting and one is already flaking off. I doubt that there are any stabilizer jacks that won’t rust.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
03-21-2021, 09:20 AM
welcome to the forum its a great place to get your questions answered. Ya the paint may be a problem with that said I don't see it as a reason to replace a stabilizer. Next time the rig is parked (either camped or stored) pull the stabilizer and clean the rust prep and paint, problem solved.
Retired Navy
2016 Flagstaff 26 FKWS
03-27-2021, 08:37 AM
I can paint them but my point is that for a basically new trailer I shouldn't have to. Is anyone else offended by Forest River calling this an "Environmental issue" on a trailer with 2,000 miles on it, never pulled on salty winter roads?
03-27-2021, 09:26 AM
Regardless of what FR has called them or how offended you may be the bottom line is they need maintenance. I recommend two days camping pull the stabilizer, clean and paint them. JMHO
Retired Navy
03-27-2021, 10:13 AM
On my TT it wasn't just flaking paint and rust.
Workmanship on the jack mechanism was atrocious. Nut on rnd of shaft welded to shaft off- center. Threads rough. Thrust bearing more appropriate for a kid's toy.
I didnt bother with a warranty claim as it would only result in replacing with same cheap item.
I bought new, Cynder brand, from Amazon. Paint far better and screw/bearing assembly is cad plated for anti corrosion.
I think that the " decision makers" figure most who see flaking paint with rust will just brush and paint, making no fuss. The few that do fuss will be a minor expense compared to what they saved.
BTW, this isn't just a FR problem.
03-27-2021, 10:24 AM
When you see rust like that it is mostly from road salt that was never washed off. Our trailer was delivered in December after a 2,000 mile voyage. Upon receipt you could see all the road salt that built up. I spent a good hour hosing off the entire undercarriage.
I suggest you spray your jacks liberally with a silicone based lubricant. Open and close them a few times spraying as you go.
03-27-2021, 10:30 AM
Easy fix! Sand and paint with a quality rust prevention spray paint.
03-27-2021, 10:46 AM
IMO
use them as they are
they will always get rusty
nobody notices the rust except you
2014 Shamrock 183
03-27-2021, 12:01 PM
Mine never saw salty roads and still look that city. They are obviously low-bid. I agree it is shameful putting these things on a camper, mine were rusty within a year of brand new. Imagine a car mfr putting on door handles that rusted like that. Truly is a disgrace. I know this company uses a lot of 'builder grade' components, but this.....c'mon man. Just because the whole industry produces turds doesn't mean they should.
03-27-2021, 12:26 PM
The picture you posted looks like mine did. If the paint wasnt totally flaked off, I could remove it in huge sheets. I swear they had fallen into the ocean on the way from China and were retrieved.
I removed and dissembled them, wire brushed, used rust reformer and repainted them. When they rust again, I’ll toss them and buy better ones.
03-27-2021, 12:43 PM
Originally Posted by rsdata
IMO
Exactly!
03-27-2021, 01:18 PM
Holy crap! THAT IS UGLY RUST!
I just lightly wire brush it and slather rust converter on it. Leaves a clear plastic finish, acid in the converter destroys rust & blackens it. Repaint or not after that.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
03-27-2021, 03:46 PM
Paint won't fix the basic problem. Cheap, poorly made and not a case of if it will break but when.
03-27-2021, 04:13 PM
Our camper stays near the ocean. I need to spend time with the exposed metal parts and clean and paint them. Steps, frame, stabilizers etc.
Stabilizers were optional and the dealer did not order them, the ones I put on are starting to rust too.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
03-27-2021, 05:20 PM
They are stabilizer jacks... with a little lube on the screws and the pivot points... tell me how they are going to break in normal wear and tear?
I recognize that it is maddening to get something brand new and there is rust on it within weeks of getting it...
but is this not making a mountain out of a molehill?
Besides tires, what takes more of a weather/road beating then stab jacks on an RV?
2014 Shamrock 183
03-28-2021, 08:13 PM
Looks about as bad as our mini lite did in less than 2 yrs. Wasn't worth a repaint in my opinion because of the shoddy materials used in manufacturing. I just replaced them with BAL. Stronger and thicker material and paint. Had I known I would have upgraded before leaving the dealer lot.
03-28-2021, 08:29 PM
In my case, one of the rear jacks failed. The foot rusted badly enough that the sides collapsed. I need to order replacements but can't decide on brand. Cynder, Libra, Huskey, BAL are the contenders.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
03-28-2021, 08:34 PM
I've have a similar awakening with my FR3, I purchased the MH "new" in Nov 2018 (it is a 2019). The vehicle had 2000 miles on it.. From the trip Indiana to CA.
2 months later, I went under the vehicle to install a steering stabilizer, and noticed that the entire undercarriage had some form of surface rust I mean a lot, not quite what the OP has . Shocked I was, but also was informed by FR when I called that while the MH was a 2018 the FORD F53 Chassis tends to sit outside in the Indiana weather for months at a time waiting for its turn to hit the factory.
Have no clue about trailer frames and stabilizers no one wants to see that!
I just took a sander and took off as much rust I could then Primes & painted, then few weeks later sprayed on Fluid Film all over the undercarriage.
I spend a lot of time on the coast near the ocean, so I know I need to do this again. It appears to work slowing down the rust. But surprising to me as the OP to say the least
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
