Old 07-11-2022, 10:49 AM   #1
RV Life Trip Planner
I'm new to using RV Life Trip Planner and so far I really like it. However, I've encountered an issue I can't seem to satisfactorily resolve. I'm planning a trip from New England to South Carolina along the eastern shore and Trip Planner insists on taking me across the George Washington Bridge in NY. I'd much prefer to take the Tappan Zee bridge. When I drag the route across Tappan Zee the rest of the route gets messed up. Is there any way I can simply tell the ap to avoid a specific bridge?
Many thanks!
2021 Flagstaff 528RWS
2020 GMC 2500HD Diesel
2019 Labrador Retriever
1983 Wife
koribustard is offline   Reply With Quote
Old 07-11-2022, 12:10 PM   #2
Try adding stops Nyak, NY and Sleepy Hollow, NY to your trip and force the route.
Russ Jones
Atlanta, Ga
2021 Ram Truck
2022 Salem 27 RK (Built 2/28/2022)
Wingz13 is offline   Reply With Quote
Old 07-11-2022, 03:12 PM   #3
Makes sense. I'll see how that works without a specific address. Thanks.
1983 Wife
Old 07-11-2022, 04:31 PM   #4
It's interesting that when I do that, it indeed takes me across the Tappan Zee then turns me around and takes me back over the bridge to where I started and continues the route over the George Washington.
1983 Wife
Old 07-11-2022, 04:48 PM   #5
You may have accidentally added a waypoint when you tried to drag the route. it will show as small white dot on the map and will show as a waypoint in your trip listing on the left side of the screen. It can be hard to see unless you are looking carefully because it does not get it’s own entry in the list of stops in the route, it will just be 1 word hidden in the list. you can delete it if you find it then try again. It took me a few tries to get the hang of doing the drag route trick.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
DougW is offline   Reply With Quote
Old 07-11-2022, 04:48 PM   #6
Kcoulter's Avatar
Palisades Interstate Parkway bans RVs (not sure about the Garden State Parkway)...that might be screwing up the routing
2020 Flagstaff Micro Lite 25BRDS
2021 Ford F-350 XLT 6.7L Power Stroke
Kcoulter is offline   Reply With Quote
Old 07-11-2022, 05:18 PM   #7
I think you are right! It seems to be restricted. My Garmin RV won't take the Tappan Zee either.
Thanks!
1983 Wife
Old 07-11-2022, 05:22 PM   #8
Who Dares, Wins
doc73's Avatar
I'd try starting a new route. Might be a pain but see if that changes anything. We just went from Cape cod to SEPA and took the tapanzee. I can route just fine with the RV trip wizard.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 07-11-2022, 05:49 PM   #9
Thanks for all of the suggestions. The trick was that I was trying to re-route south too soon and was hitting restricted roads/highways. I simply had to keep going west to I-287 until I can loop back into I-95 around Newark, NJ.
1983 Wife
Old 07-11-2022, 08:18 PM   #10
camaraderie's Avatar
Bingo! That's exactly what I do to get to south on the Jersey Turnpike from New England. Anything that says "parkway" in NY, NJ is usually trouble for RV routing. RV Trip Wizard is a super app...you can't even do that on a lot of the simple trip planners. Good luck.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 07-11-2022, 09:17 PM   #11
Hey, kori, thanks for coming back and telling us what was in fact causing your problem. Certainly helps all of us.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 07-19-2022, 07:26 AM   #12
Add in Mawah NJ which will put you on 287 South then you can decide if you want to go all the way down to the Jersey Turnpike or go 78 west to 33 South (2 lane mostly but scenic) to 295 south to Delaware to eastern shore around Baltimore &DC
Rambling Kids is offline   Reply With Quote
Old 07-29-2022, 02:57 PM   #13
Having tried EVERY mapping program for my Harley, I know this frustration.
I review my route 3 or 4 times and zoom in as far as possible when I add a waypoint by dragging a route. Inevitably, I find 3 or 4 waypoint that I did not add. The issue is, if you remove that waypoint (at least on the programs I have used) it takes the route back to the way it wants you to go.
I have learned to go back to old school and study a map and know my route.
With a Harley, getting lost is not always bad, pulling a trailer though......Whole different story.
Glenncarp is offline   Reply With Quote
Old 07-29-2022, 10:27 PM   #14
With a motorcycle you are never lost as long as you still have gas.
Old 07-30-2022, 07:05 AM   #15
Steve & Linda M.
MevetS's Avatar
Assuming you're talking about Trip Wizard. Have you tried the Drag Route feature ?
Between Drag Route and adding POI's you should be able to route yourself as you wish.
It's often easier, at least for me, to break trip legs into separate routes.
Started in the "Pumpkin" '79 Burnt Orange Dodge "Street Van" ... NW cruise, Canadian Rockies, Round trip to Alaska. Then' 94 Tioga Montara, '06 Jayco Jay Flight 5th Wheel. Workmanship decline started : '15 Thor Siesta & '17 Tiffin Breeze.
Another RV learning experience with our 2022 34KD Force.
2019 Jeep KL (Cherokee) TOAD
MevetS is offline   Reply With Quote
Old 07-30-2022, 11:14 AM   #16
PhilFromMaine's Avatar
I think the secret to using Trip Wizard (or whatever its called) is to use a lot of way points and then zooming into the map to verify that is what you want. You have to look at your route very closely or it end up biting you.
The only way to use the GW bridge is at 3AM and even then I wouldn't call traffic light.
PhilFromMaine is online now   Reply With Quote
