05-03-2018, 09:26 AM
RV Parking Spot Material
My RV parking spot is gravel covered. Is gravel safe for tires? Would wood planks where the tires rest be better? Does treated lumber damage tires?
05-03-2018, 09:34 AM
Insert witty title here
Gravel is fine. That's what my TT parks on.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
05-03-2018, 09:38 AM
Gravel is fine. Wood can be used if it gets wet and might sink a bit. My trailer is on a asphalt lot we use wood to disperse weight
B and B
05-03-2018, 09:42 AM
Kanadian Kamper
Gravel is better than asphalt. The oils and such in asphalt can leach into the tire surface if parked too long.
Dirt can become mud.....not good.
Grass is usually too soft and you can sink in, and ultimately kill the grass if parked there time after time.
The more expensive campgrounds have concrete pads....level (doesn’t always neeed jacks) and can support just about any rig.
Gravel allows drainage under the tires.
Ken and Terry
05-03-2018, 09:44 AM
This has been discussed here several times before with the consensus being gravel is fine. (often preferred as it lets the water/moisture escape from contacting the rubber)
The consensus about wood blocks is that's OK too but there were concerns about the chemical in 'treated' lumber leaching into the rubber. Never seen any scientific proof one way or the other.
05-03-2018, 09:58 AM
your tires probably don't really care, but you can also easily thrown down some heavy/thick 'truck matting' under each tire if it makes you feel better.... it's like a cushion of air!
05-03-2018, 10:00 AM
I like that, old fender flaps! Upcycle old stuff.
B and B
05-03-2018, 10:08 AM
I prefer to place just fir 2"X8"X10' boards under my tires when in storage on a gravel lot. This way in the winter months the tires are out of water due to spring time thawing with the ground still being frozen from winter.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
05-03-2018, 12:51 PM
I also park/store mine on gravel. In addition I use 2 pieces of rubber matting material, about 1’ x 4’. I leave them in place, & use as a locator so I know I’m in the right spot for slides to open etc. inside by RV “Barn”.
05-03-2018, 03:48 PM
Gravel works great. I have mine on 4 inches of regular gravel and then 2 inches of white pea size gravel. Never gets muddy or sinks.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
05-03-2018, 03:53 PM
We park ours on concrete pavers, which work well.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
05-03-2018, 04:23 PM
I poured two 60” concrete pads in my carport for the trailer tires to park on. About $50, lot cheaper than a 25x40 ft. floor and always have a level trailer.
BIRDS AREN’T REAL
05-03-2018, 04:46 PM
parking on?
From a home improvement store I bought some rubber pavers that are made from recycled tires. They are 3/4" x 16" x 16" just big enough for dual tires. They are also grooved (to look like stone) so that leaves are channel for the water to run off. I use them on my RV pad and when in the barn for winter storage.
05-03-2018, 05:48 PM
Just as confused as you
Originally Posted by kenandterry
The more expensive campgrounds have concrete pads....level (doesn’t always need jacks) and can support just about any rig.
Our campground poured concrete pads for their seasonal sites. They quit after everyone started to park their trailers so they could use the pads as patios. Now they will put in a patio pad if you pay them extra for the site.
Richard & Jill
05-04-2018, 07:49 AM
I use treated 2x10s on crushed concrete,,,
Up until last fall it was outside,,, until we had an RV Port built !!!
05-04-2018, 08:03 AM
I have used a CR6 pad for the past 10 years with no issues.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-04-2018, 08:28 AM
CR6 crushed stone ???
