RV Proflex
I learned a lesson about using clear RV Proflex caulking. I was placing the RV Proflex caulking on some external vertical seams. I placed the blue tape along the seam. Then put on the Proflex. I started at the top and went down to bottom. I tried to smooth it by using soap on finger. It did not smooth very well because it was already drying. Then tried to remove the blue tape. The Proflex was very stringy. I tried to smooth some more but would not smooth. This vertical seam looks looks like a very bad application. The other places that I caulked, I did not use the blue tape. I went just a couple of feet, smoothed out before it would start to dry and then applied another short length, smoothed out as I went. These other places looked very good. Proflex dried very quickly and will not smooth out once started to dry. Since the one vertical seam looks so bad, should I take off and do over again? If so, what should I use to remove the poor caulking job? It appears to seal good but just looks bad.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
