08-27-2016, 11:45 AM
RV Water Hoses - 1/2 " or 5/8"?
As a new member to RVing, which is the better water hose to use - 1/2 or 5/8 inches?
08-27-2016, 12:10 PM
I learned the hard way. I got "nice hoses". Posted a pic. Someone said "Hey, those are 3/8" hoses".
Duh. Yep, they were. *slapping head*
So I got more hoses.......5/8"......from these folks. If you need it, they got it.
https://www.plumbingsupply.com/choos...rden-hose.html
be careful to get hoses marked "for potable water".......
FROG AR-0019-242
08-27-2016, 12:11 PM
water hose
5/8" equals more volume. Good to have more volume
South Bend Indiana
Rockwood, 2015 Ultra V 2715vs
05 gmc 2500HD Duramax/Allison
08-27-2016, 05:14 PM
Ok - Last question - will a 25 ft. hose length be sufficient in most Rv Parks? - Thanks
08-27-2016, 05:17 PM
OK - Thanks - Last question - Will a 25 ft. hose length be sufficient in most RV parks?
08-27-2016, 05:20 PM
No way to know. I have a 25, a 50, and a 10 that goes on the camper side of the outside water filter. I've yet to connect both 25 and 50, but I have used both at times.
FROG AR-0019-242
08-27-2016, 05:28 PM
Buy two 25 footers, use what you need.
I carry two 25 and one 35, never know when it will be handy.
08-27-2016, 05:30 PM
A 1/2" hose 25' long @ 40 psi = 24 gpm.
A 5/8" hose 25' long @ 40 psi = 44 gpm.
There is quite a difference there.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
08-27-2016, 05:47 PM
I have two 25' 5/8" potable water hoses and until a couple weekends ago I've never needed but one of them to make it to the water faucet, but on that site the pedestal was at the back of the site and it took every inch of both hoses hooked together to reach. I was sure glad I had that second hose. So, as said above, you never know.
I plan on buying a third hose just to be safe. I'd definitely recommend getting at least two hoses.
Gotta go campin!
08-27-2016, 05:59 PM
keep in mind, you're in an RV not at home in a house, we carry a 10' and 25', ... both are 1/2" and provide all the water and pressure we could ever want, a 5/8" hose is just more bulk,... I use the 10' if I can, the 25' if I can't, and the 35' if needed,.....
08-27-2016, 09:24 PM
I had been using 5/8 for the last 3 yrs and needed a new hose on our current trip and got 1/2 cause they had lots of it and a good price. I haven't noticed any difference over the 25 ft I have ran it...perhaps I would over a longer distance. Keep in mind that as soon as the water reaches the trailer plumbing it's all 1/2 inch anyhow.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
08-27-2016, 10:28 PM
More bulk?!? Come on, man! We carry two 25 footers. Most of the time one will work, but sometimes I hook up both just to be able to put them under the RV and out of the way, depending on where the pedestal is.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
08-27-2016, 10:44 PM
yes, a 5/8" hose is more bulk than a 1/2" hose, duh??.... to each, his own!...... maybe you need a large hose?,.. but all of us aren't towing a 32', 9,000# 5er,..... so for some of us, a small hose works just fine!.... and I would also imagine that thru that large hose you only get "all the water that you need", and to your surprise, we get the very same amount thru our small hose, thru it we get "all the water that we need",... how about that? .......
08-28-2016, 12:22 AM
And all your fixtures are most likely water conservation fixtures at 1-2 gpm. You could turn on every faucet in the rv wide open and still not reach 24gpm. In addition if you're in a site without sewer, do you really want to fill your holing tanks that much faster and have to either pull down to the dump station or use one of the dump dollies?
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 21/18 = 11
08-28-2016, 01:35 AM
So you figure using a larger hose will cause your holding tanks to fill up quicker? I think maybe I will switch to a 1/4" hose then.
08-28-2016, 08:54 AM
If you manipulate the fixtures and remove the water saving portion, yes they will because you can then supply 44gpm.
Bob
08-28-2016, 11:45 AM
08-28-2016, 12:17 PM
you can use a fire hose if you want, you are still limited to the same flow from the small pipes and low flow faucets inside the RV
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
08-28-2016, 12:45 PM
To the OP
Bottom line is you will have the same water flow out of your faucets whether you use 1/2" or 5/8".
08-28-2016, 12:49 PM
To the OP
If that's true, and if outside flow is immaterial, then why is a regulator suggested to be put in the line outside????????????????????
FROG AR-0019-242
