Old 11-15-2016, 08:03 AM   #41
Insert witty title here
Those clearance signs could be a couple of inches off if they paved since the sign was installed.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 11-15-2016, 09:09 AM   #42
Working in a shop, I pulled the motorhome in until the highest point (a/c) was under the garage door and pulled garage door down on the unit then measured to the floor and of course I had proper tire pressure too...
Davidjeff is offline   Reply With Quote
Old 11-15-2016, 09:11 AM   #43
I agree, I allow 6" minimum and added that to my height measurement to put on the sticker on windshield allowing for CRS !!!!
Old 11-15-2016, 09:50 AM   #44
My TT is 11' high. The rule of thumb I use is if the sign shows below 11' 6", I go around. 11'6" - 12' the DW gets out and watches as I slowly creep under, 12'+, I don't worry
Old 11-15-2016, 10:08 AM   #45
I don't worry if I'm 13ft 4 or 5 and the bridge says 13ft 6in. It may as well be a mile high. Any bridge that says 13ft 6in I can get under. Commercial trucks can get under the bridge I can too. If a bridge isn't marked it's at least 13ft 6in. I have a B&W hitch and I could drop it down a inch. If I was more that 13ft 6in tall and I could not drop the camper down then I would look to trade camper. I take the wrong road all the time and I'm not going to worry about being to tall. Just my two cents
spock123 is offline   Reply With Quote
Old 11-15-2016, 10:10 AM   #46
Mddle of the Rd Extremist
MeepMeep's Avatar
Originally Posted by mnolasco View Post
I'm a new owner of a 13'-6" tall fifth wheel. I'm worried about taking roads with 12'-13' bridges. I'll be traveling in unfamiluar areas. Is there a smart phone AP that solves this problem? Or a map book with routes for tall rigs?
One of the more definitive sources I found is the Rand McNally Deluxe Motor Carriers' Road Atlas.....lists the low clearances by state, along with much other valuable info
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 11-15-2016, 01:15 PM   #47
There is a 11ft 8in tall railroad overpass in Durham, NC that shows a RV creeping under the overpass and it cleans both a/c units off the top. But a lot of trucks and rvs have hit that overpass. Just check out 11foot8.com
Old 11-15-2016, 02:27 PM   #48
Anyone thinking about using the "Low Clearance POI - GPS Data" beware that not all gps units will allow the files to be added. I have a Magellan Roadmate that customer support at RT-1 said there POI file could be added to but after purchase I find that they lied. Also be aware that without telling you it is set up as a subscription and will auto charge you each year.
Retired Navy
Indiana
Hemisphere Lite 327RE
Silverado 2500HD 4x4 6.0 gas
Sailor Bill is offline   Reply With Quote
