Old 11-24-2021, 10:33 AM   #1
ARLO
sheet vinyl flooring
Has anyone had to replace the vinyl floor covering in their TT yet? Is it put down with adhesive?
rlocicero is offline   Reply With Quote
Old 11-24-2021, 10:43 AM   #2
I believe the vinyl flooring is put over the entire floor before any walls or cabinets etc. I would think that it is just secured at the edges. I had mine cut and peeled back to replace the flooring beneath in our 2011 for some soft spots. It was not glued down.
KKonyha is offline   Reply With Quote
Old 11-24-2021, 12:28 PM   #3
ARLO
[QUOTE=KKonyha;2664792] what did you use for the repair. My floor is in good shape, no water damage, just spongy in a couple of spots.
How did you replace the subfloor? I had planned to pull up the vinyl and cover the existing floor with 1/4" luan and re-use the vinyl. it is in great shape and could be retained with 1/2 round molding.
Old 11-24-2021, 12:37 PM   #4
I had to rebuild my floor so I stripped the luan/insulation sandwich down to the aluminum floor joist and used solid wood to bring it up to the existing good floor. This was in the bathroom so it made a better base for the toilet.
floor, flooring
