Used to pull a 24' dual axle trailer and a 20' boat. We just bought a Mini Lite 1905 single axle. The crappy old 1/2 ton pickup enjoys the smaller trailer much more than the old, heavy 24'. As for backing, sometimes the curse is the blessing. Yes, you can get jack-knifed easier and small moves have bigger impacts. The other side of the coin, however, is that once you get used to the shorter trailer you can back into some pretty tight spots that would have been harder or impossible to get to with a longer trailer. As many have mentioned, we tend to camp at BLM and Forest Service camps that are not designed for larger trailers. Our shorter trailer has opened up some options. Since the 1905 is about the same length as the boat, we were already calibrated to the "shortness" for backing. I think once you get used to it, you will like that it is shorter.
As for the trailer, the 1905 is perfect for us as a couple, light, easy to pull around, and enough room for the two of us. The Murphy Bed is the best as it makes the trailer feel spacious during the day but then you have a walk around (sidle around) queen bed at night.
2018 Rockwood Mini Lite 1905 (No Front Window)
Crappy old '98 Dodge Ram 1500
