Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 01-14-2022, 08:00 AM   #1
Fully COVID-19 vaccinated
Sizing a new converter / charger
I am getting ready to ditch the lead acid batteries and make the jump lithium. The question I have is how large of a converter charger do I need. I plan on starting out with (2) 100Ah batteries but may add more.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 01-14-2022, 09:47 AM   #2
SeaDog's Avatar
Have you checked to see if your current converter will handle the new batteries you may not need a change unless the charging profile won't work.
Retired Navy
2016 Flagstaff 26 FKWS
Old 01-14-2022, 12:45 PM   #3
Lithium batteries generally have a .5 C charge rate recommended.
2x 100ah batteries will charge well with 55-60 amp converters. Larger converters require larger 120 volt supplies with "12 awg wire and 20 amp breakers. Most stock converter wirjng is #14 awg and 15 amp breaker.
As suggested, check to see if existing converter is lithium capable.
If not I'd suggest a converter like the Progressive Dylamics 9160ALV and mount it as close as practical to the new batteries.
Extending the 120v converter wire to this new location is a lot less expensive than upgrading 12v wire to at least #4 awg welding cable and yields a the fastest possubke charge times.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 01-14-2022, 01:32 PM   #4
This is spot on. 2x100Ah LiFePO4 (LFP) should handle 100A charge just fine. Hard to get that in a standard converter/charger. My 5er has 10 ga wire for the converter/charger AC input and a 20A plug but they installed a 15A circuit breaker for the converter/charger. So my limit for off the shelf converter / chargers was 60A. Above that, they go to a 20A AC cord. 60A will get you from 20% to 90% in 2-3 hours with 2x100Ah LiFePO4s.
I got the Progressive Dynamics 9160ALV which is 60A and it was ok. Kindof caveman in that it is two stage but not adjustable. And it is LFP only, so if you want to take your LFP with you to your next camper, you are SOL. Couldn't find a better option, but others should chime in.
I now have an inverter/charger and got rid of the converter/charger. My inverter charger (Victron Multiplus II) is a 120A charger and I have pushed that much into my 2x206Ah SOK LiFePO4 batteries.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL
Andersen Ultimate
800W solar > 412 Ah LiFePO4 > Victron MultiPlus II
corn18 is online now   Reply With Quote
Old 01-14-2022, 01:58 PM   #5
camper_Lucy's Avatar
This video may help you out a bit. (seems easier then a bunch of us typing notes - then we can answer questions)
2019 Chevy 3500 4x4 Crew Duramax
2021 Gray Wolf Toy Hauler
2019 Street Glide
camper_Lucy is online now   Reply With Quote
Old 01-14-2022, 02:02 PM   #6
This is an important point that most miss, my guess is your current wiring is #6 agw so a new wire is the way to go.
2019 Street Glide
Old 01-14-2022, 02:24 PM   #7
I'm currently looking at Battleborn. They have a few different converters to choose from, thus my question.
Old 01-14-2022, 03:46 PM   #8
Any of those recommended by Battleborn will work.
I am a fan if Progressive Dynamics.
I only need one and the PD converter I have has performed flawlessly.
Pick one.
2004 Nissan Titan
converter
