Originally Posted by jlbreaux
I traced positive from battery compartment to inside of the frame, did not see any inline fuse. May be the battery, it is not dead, but is weak. My next step is to check voltage at the motor. Hope it is the battery, it will save me $100 if it is,
Do you have a volt meter? unhook the battery cables from the battery... The red cable should be 'hot' when the camper is plugged into 110. The convertor should be sending voltage to the positive cable to charge the battery. check the voltage and make sure that the
hot wire has voltage and the negative is grounded good. If no voltage... find out why.
the inline fuse should be under the front of the camper lip area. Follow the positive battery cable to the first area contact point. Is there a resettable (push button) fuse in that area?
