Originally Posted by PuppyDogMom
.....Just picked up my camper from winter storage and the motor to the slide out does not work.....
You guys are all saying a dealer needs to be involved?
We have officially put the cart before the horse....
This is like someone posting on a car forum and saying "my car doesn't run, help." Before calling in the cavalry, let's go through a process of elimination and hopefully avoid an unnecessary trip to the dealer. Start small and work your way up.
What we know:
1. The slide motors don't work.
2. It has been stored for the winter.
So why now is a dealer needed?
OP please answer the following questions:
1. Did the slide work prior to storing for the winter?
2. When you tried to use the slide out, did it make any noise whatsoever?
3. Since storing, has your battery been fully charged and showing 12+ volts?
4. When you tried to use the slide out, was the trailer using battery or shore power?
5. Have you checked the fuse (it will look like a car/automotive fuse instead of a house breaker) and is it ok or blown?
My guess is:
1. The battery(ies) is dead and the slide won't work.
OR
2. The fuse is blown. This can happen from using the slide from battery power. The lower voltage (instead of shore power) causes the slide to draw slightly more amperage when the slide comes to a stopping point and blows the fuse.
Please let us know what you find for us to help further diagnose the issue. It is likely something very minor.
