Old 04-12-2017, 01:10 PM   #1
Rhody's Avatar
Spray Foam Blues
I have a 2016 25' Freedom Express. While I was at the local RV Center I asked them if they could install a black water Flush on my RV they said no problem.
They came back to me in the waiting room 10 minutes later and stated that they could not work on Anything that is Under the TT because it has been completely Spray Foamed from end to end!
OUCH!!!
Rhody
Rhody is offline   Reply With Quote
Old 04-12-2017, 01:47 PM   #2
raforan's Avatar
thats just them not wanting to do the work. i just put a hitch on my frame on my freedom express and yes it has foam but a razor blade and it comes off. then you just spray foam back over the gaps with exterior foam that is water resistant.
2011 Coachmen Cattalina 26bh SOLD
2016 Coachmen Freedom Express 31SE
2006 GMC 3500 Duramax Dually
2017 Nights Camped 75 and counting
2018 Nights Camped 40 and counting[/b]
USMC 2005-2015 OIF OEF
raforan is offline   Reply With Quote
Old 04-12-2017, 06:05 PM   #3
Rhody's Avatar
Foam Blues
I had a feeling I was getting blown off...
How hard is it to install anyways? Not that I am a Bob Villa...
Rhody
Old 04-13-2017, 08:16 AM   #4
raforan's Avatar
in reference to the black tank flush install. I am not sure, as for the hitch it was easy. take the three 10mm self taping screws out of the under and cut the foam. fold down the under skirting and set the CURT Adjustable RV Trailer Hitch #13703 on the frame and follow instructions. slit the undercoating to fit around the hitch and replace screws and purchase spray foam from lowes or home depot and spray in cracks between body and under skirting and trim as needed
