Your best bet is going to be installing some sort of triangulation stabilizers like the JT Strong Arms or SteadyFast. I like the SteadyFast system as it's less bars, easier on the hands, and same (or slightly better) performance. Plus the customer service is out of this world - the owner literally includes his cell number in the instructions.
Are you asking about the procedure using the stabilizers already attached to the R/V or are you looking for additional stabilization such as ependydad mentioned to remove some of the rocking/bouncing?
Are you permanent or do you move around?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
F&AM Lodge 358 Somerset, PA - JAFFA Shrine - Altoona, PA Days Camped: '17=38 ☼ '18=49 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=88
I posted a Picture here one time of a Windjammer at a Fla campground with (14) additional screw jacks under it,even the slides and they still were not happy with the "Movement"! I told them they needed more support under the Steps ,so they did that also! Youroo!!
