Old 11-22-2020, 12:11 PM   #1
Stabilizer Jacks for Lifting the Trailer
It appears that folks recommend against raising the trailer by using the corner stabilizer jacks. My stabilizer jacks are weight-rated substantially above the trailer weight. So its not clear to me why I shouldn't use them to jack the wheels off the ground. Could someone explain why this would be a problem. Thanks
Less is More is offline   Reply With Quote
Old 11-22-2020, 12:15 PM   #2
nomad297's Avatar
You can twist the frame temporarily or permanently, throwing everything from your doors to your slides out of whack. Permanent frame damage could result in many more bad things happening.
Bruce
Old 11-22-2020, 12:37 PM   #3
mjones12's Avatar
Bruce
X2.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 11-22-2020, 12:59 PM   #4
X3. Plus the manufacturer of the trailer is very likely to also state that the corner stabilizing jacks are not to be used for lifting the trailer.
NavyLCDR is offline   Reply With Quote
Old 11-22-2020, 01:03 PM   #5
Possibly might bend something, likely maybe not.
Picture your frame 30' long, bouncing the weight over the axles rolling down the road. The axle mounting roughly separates the frame into 2 -15' pieces as far as the load it needs to carry. Lifting from the ends you now have a 30' span to keep from bending. But those 2 15' spans were only "supported" at one end the other end hung in free air and didn't bend downwards as you bounced down the highway. So as you can see, to say you'll fold the trailer up like a suitcase without doing load calculations on the steel frame is just a guess, so is saying nothing will happen.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 11-22-2020, 01:51 PM   #6
mike.t's Avatar
Not trying to be a smart a*&, they are called stabilizer jacks, they stabilize
2018 Wilderness 2450FB
2021 Chevy Silverado 1500 3.0 Duramax 10 speed
2021 Chevy Traverse LT
2012 Dodge Challenger
If you get to thinkin' you're a person of some influence, try orderin' someone else's dog around.
mike.t is offline   Reply With Quote
Old 11-22-2020, 02:44 PM   #7
Ok How about this
What if you just raised it a little to ease the jacking it up?
TGO Bill is offline   Reply With Quote
Old 11-22-2020, 03:26 PM   #8
Your jacks may be rated for the trailer weight, but that weak ars frame will twist like a pretzel.
campers302 is offline   Reply With Quote
Old 11-22-2020, 03:38 PM   #9
D W
D W's Avatar
All of the above, plus the motors are not powerful enough to stand that amount of load.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 11-22-2020, 03:41 PM   #10
X2.
It's generally recommended not to lift weight with the 'stab jacks as most simply are NOT rated for much weight.
If you truly have scissor jacks rated for weight, you probably could lift it high enough to get the tires off the ground but most frames won't stand being raised at each end without bending/buckling in the middle unless a very short wheebase or a pop-up.
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 11-22-2020, 03:42 PM   #11
Good to know.
Tahoe John is offline   Reply With Quote
Old 11-22-2020, 09:25 PM   #12
BillyBass's Avatar
X2
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 11-22-2020, 10:14 PM   #13
Oaklevel's Avatar
I hope that you listen to the others advice. Not a good idea to lift the trailer any other way but as it was designed.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 11-26-2020, 12:40 PM   #14
mjones12's Avatar
I have seen several people just this week trying their best to get their campers level with the stab jacks and a power drill.
It's so easy just to roll onto Andersen levelers on the low side and then level front-to-back with the tongue jack.
As someone else pointed out, they are called stabilizer jacks for a reason.
jacks, lift, stabilizer, trailer
