Old 01-29-2021, 10:21 AM   #1
Steve from Maine
jaudet71's Avatar
Stink Hose Storage
I am was planning to be in Arizona now. But due to covid we decided to stay home and stay safe. So I am posting a few mods to amuse myself and others as it is 9 degrees and windy here today.
I needed a place to store my stink hose that is two hoses together and the 90 degree clear elbow. I didn't want to waste storage compartment space. I don't have a bumper and those usually won't fit the elbow anyway. If I had a storage bumper I would of just used that and dealt with the elbow.
So I was looking in my propane storage door and noticed a lot of unused space. So I bought the 6" pvc pipe kit from HomeDepot.com that they use for storage on plumber's vans and such. I used a pvc cap at the other end and drilled holes for drainage so I can rinse it out. I made sure I mounted it with a slight pitch. My propane Is just a couple doors away from my tank drains so all is close by at dumping time.
Now I just slide both hoses and the elbow in as one unit and it is all hidden and done without using existing storage space. Don't make it any longer than needed so the hose doesn't slide down out of reach.
You just need to get the 6" pvc at a plumbing supply store as HD doesn't carry it at stores.
ID:	246888   Click image for larger version
ID:	246889   Click image for larger version
ID:	246890   Click image for larger version
ID:	246891   Click image for larger version
Retired UPS Driver
2015 Georgetown 270s
960W solar, 60a Renogy MPPT, 510ah Li
10CU.F GE dc only fridge
2019 Jeep Wrangler Unlimited
2008 Yamaha WR250R
jaudet71 is offline   Reply With Quote
Old 01-29-2021, 10:56 AM   #2
I mounted a 5" post cover on my bumper and slid a piece of gutter in it to act as a drawer. The end caps are held on by cotter pins so it is easy to remove them.
https://www.forestriverforums.com/fo...ture16974.html
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 01-29-2021, 11:03 AM   #3
Steve from Maine
jaudet71's Avatar
That's clever. Looks good.
Retired UPS Driver
2008 Yamaha WR250R
storage
