Originally Posted by ejohnson1144
Sounds like your over heat safety is tripping and resetting usually an air flow problem . check duct work
This is quite possibly the problem, but the burner usually shuts down quicker than 5 minutes. Try cleaning out/blowing out your intake and exhaust while the furnace is turned off.
I blew mine out with a leaf blower once by directing the air into the outside lower intake, which forced air through and out of the upper exhaust. Worked like a charm.
Bruce
