02-26-2018, 08:34 PM
Sun Shade off awning
Have 2017 Coachmen Mirada Select 37 TB—-could anyone tell me what length sun shade they purchased. I know the width of my awning is 18 feet, so I will go with 17 feet for the width. I want the awning to touch the ground so I’m thinking 9 feet. Is that too long?
Thank you, Shelly
02-28-2018, 08:07 PM
Thank you, Shelly
That would not be to long, I hang mine at a angle to shed rain a little also gives you a little more protected area. Mine is staked out at like a 45 degree angle.
Coachmen M/H
Concord
2018 / 300 DSC
03-01-2018, 09:10 AM
Thank you. What do you think about the zipper ones? I would think the the 1 ft screen that would roll back up into the screen would eventually damage the awning fabric from rolling in and out.
03-01-2018, 09:20 AM
No damage if you buy a Quality one like from "J & J Mats and Sunshades"! Youroo!!
03-01-2018, 09:34 AM
Here's a sun shade that is a 2 piece. The one shown is a 4' section and an additional 6' section zips to it so it touches the ground. The 4' section stays with the awning when rolled up. It does not affect the awning fabric in any way. The 4' section is standard and whatever length is necessary for the second section to reach the ground is ordered with it.
03-01-2018, 10:47 AM
I have the 1' section, but i dont like it rolled up, really it just as easy to thread it in the grove as it is to zipper it up, IMO only, plus they cost more which is a waist if your not going to use the zipper.
Coachmen M/H
Concord
2018 / 300 DSC
03-01-2018, 10:57 AM
I see the need for the "Hang Down Zipper" because of the "Height" of the units,a ladder would be needed to install! That being said W/D is correct in that the "Hang Down Part" must be secured in some way or it "Blows and Moves" in the wind which can be very distracting! Youroo!!
03-01-2018, 12:44 PM
Kinda agree, but I just pull my awning down and lock the arms to install the material in the grove, I just don't like the bulk or added weight rolled up, if I can bend or brake something I will. Your roll up would be pretty big with let's say a 4' drop, I would want a center surport installed when rolled up, CHEAP ROLLERS could bend when traveling.
Coachmen M/H
Concord
2018 / 300 DSC
03-01-2018, 04:03 PM
I have 1 by Carefree. 2' hang stays on and 6' zippered. Works fine.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
03-01-2018, 04:23 PM
The zipper is plastic. In 3 years of having ours it has not damaged the awning.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-01-2018, 05:53 PM
This company makes a 2 pc sunshade. Once dusty, zippers don't work well. I asked if they have a "hook" model, they do. I need a 2' pc to remain on the awning. rvmat.com | Our Sunshades
03-02-2018, 11:03 AM
We have the Carefree with a two foot drop and a six foot zippered extension. Never a problem. Rolls up with never any awning problems and never had dirt problems getting into the zipper. It takes about two minutes to zip in the extension. Highly recommend it!
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
03-02-2018, 05:43 PM
Thanks for the info Lloydg. I think 2' with a 6' drop is going to work too.
03-03-2018, 12:26 PM
I went to measure the awning and instead of measuring groove to groove I measured end of awning to end of awning which came out to be 17’ 3”. The total length of the awning is 18 ft. I guess a 17 ft sunshade would work?
03-03-2018, 12:32 PM
What width across did you get?
