Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-10-2020, 11:15 AM   #1
Super quiet 3500 watt inverter generator
Just wanted to tell the group of a generator find I made after extensive search.
I was looking into the HARBOR FREIGHT PREDATOR "3500 Watt Super Quiet Inverter Generator". After reading and researching I found that the NORTHERN TOOL "Powerhorse Inverter Generator ó 3500 Surge Watts, Model# LC3500i" was the SAME generator
There are 2 MAJOR DIFFERENCE between the Harbor freight & Northern tool genset.
  • The Northern Tool Product was $699.00 while the Harbor Freight genset was $799.00 (749.00 on sale)
  • "Both Vendors offer an 2 year limited warranty but with on huge difference. Northern Tool offers "in house repair" of the product while Harbor freight does not."
The product is VERY QUIET, I ran the new generator under 75% load and it hums.
This generator is perfect for my adventures dry camping, under the stars in Everglades National Park.
Hope this helps.
Florida Traveler
Pembroke Pines, FL
2018 Wildwood x-lite 230BHXL
2021 Ford F-150, 5.0L Super Crew
Retired, Electrical Engineer
USN Vietnam Vet Brown Water Navy PBR 534 1968 - 1970
Florida.Traveler is offline   Reply With Quote
Old 05-11-2020, 08:17 AM   #2
noise
IMHO: 57 decibels at 1/4 load is not Super Quiet.
There are other units that out there that are under 50 decibels at 1/4 load and at full load only 1 decibel higher than the Powerhorse at 1/4 load.
C.B.
cbvp is offline   Reply With Quote
Old 05-11-2020, 08:43 AM   #3
Broken Toe
Cowracer's Avatar
C.B.
Please list them, as I am sure they are nowhere near the price or wattage.
For the record, Norethern Tool must have upped the prices, as they list them at $749 now. Still $50 cheaper than Harbor Freight.
You can get a "DuraDrive" copy, which again is the exact same generator for $699
Here
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is online now   Reply With Quote
Old 05-11-2020, 09:08 AM   #4
My reply had nothing to do about price. Only noise.
Like I said IMHO 57 decibels at quarter load is not super quiet.
C.B.
Old 05-11-2020, 09:35 AM   #5
C.B.
Agreed.
57dB at 25% load vs 49dB at 100% load. Considering that a 10dB increase in sound is interpreted by the ears as being twice as loud, that 8dB difference means that most people would consider the cheapie running at 1/4 load to be almost twice as loud as the more expensive one running at full power. Run both at full power and the noise difference would be even worse.
It matters, of course, from how far away you take your measurements and I don't see that in either spec sheet. I don't know if there is a standardized test distance or not. Even though the cheapie may be considered quiet, it certainly shouldn't be classified as super quiet, IMO.
gastan is offline   Reply With Quote
Old 05-11-2020, 10:52 AM   #6
Broken Toe
Cowracer's Avatar
C.B.
Shouldn't we stick to comparing apples to apples? Sure a Honda 2000 watter at 1/4 load will be quieter. By a whole 4db (and for arguments sake, a 3db gain is the level that the average human ear can discern a difference in loudness between two sources.)
If we look at 3500 watt generators. 57 is pretty damn quiet.
Tim
"Camper" 2016
Old 05-11-2020, 11:51 AM   #7
gen
Tim
No It's Not!
Since you brought up Honda
3000i (handi) 52@1/4 load 58@ rated
3000is 50@ 1/4 load 57@ rated
7000i 52@1/4 load 58@ rated
If you'll notice the Powerhorse doesn't give a decibel level at ratedv power.
Mmmmmm Wonder why that is?
C.B.
Old 05-11-2020, 12:31 PM   #8
Broken Toe
Cowracer's Avatar
No It's Not!
C.B.
3000I is $2300
300Is is $2100
Powerhouse is $750.
You are not comparing same class of generators. It's like saying a Mercedes is a nicer car than a Chevrolet. Of course it is.
Tim
"Camper" 2016
Old 05-11-2020, 01:16 PM   #9
Like I said before.
I'm not comparing Price. Just noise level.
A generator with a noise level of 57 decibels at 1/4 load at any price is NOT and should NOT be advertised as a SUPER QUIET generator.
C.B.
Old 05-11-2020, 02:09 PM   #10
bikendan's Avatar
Like I said before.
C.B.
It would be SUPER QUIET, next to an open frame contractor-style generator. How do you know that they're saying that and referring to other inverter generators?
It's just marketing.
Old 05-11-2020, 02:53 PM   #11
rfifer
As a point of reference, easy conversational speech is about 60 dB to 65 dB. Perceptually, a 10 dB difference is either half as loud or twice as loud depending on the direction you are going. From this audiologist's perspective, you are starting to split hairs. 57 dB is very quiet for a generator and, yes, 49 dB is quieter. But sound really starts to interfere with your ability to converse as it goes above 70 dB and is really bothersome at 75 dB+. The scale is logarithmic and not linear. So, 65 dB to 70 dB is a much greater change in sound force energy than 50 dB to 55 dB. Both values (49 dB and 57 dB) discussed here are quiet, just different degrees of quiet.
Bob and Jan
Miami
Grey Wolf 26 DBH
TV F-150
rfifer is offline   Reply With Quote
Old 05-11-2020, 03:57 PM   #12
I've got to jump in here. I've had and enjoyed a Generac 3000 used at home base, then a Yamaha 2000 when camping, the Honda companion setup, a Boliy 3000, a Champion 3500, and now the best yet, the Westinhouse 4500. All were inverters except the Generac. My point is this...each one did a good job supplying needed electric for my purpose, increasing output as my demands increased. Noise was acceptable when set up correctly. But here's the thing. The Westinghouse, also available as a Cummins, is powerful, not too heavy, quiet under load and when on eco, and remote start/stop. 3 year warrenty and less than $900 from; damn, I can't remember. Hope this helps. I'm done.
Steveg is offline   Reply With Quote
Old 05-11-2020, 04:04 PM   #13
Just got off the phone with powerhorse tech.
Powerhorse
Model LC3500i
69 decibles at rated load.
Honda
Model
3000i (handi) 58 decibels at rated load
3000is 57 decibles at rated load.
C.B.
Old 05-11-2020, 04:08 PM   #14
Originally Posted by Florida.Traveler View Post
<<SNIP>>
<<SNIP>>
Hope this helps.
Thanks for the tip.
For a $1550 savings over a Honda, and 500 watts more starting power to boot, this is a great option, even if it is slightly noisier.
A friend has a 2KW Honda and a 2KW Predator, and he pairs them to run his AC. The SPL difference is undetectable in the real world, especially when they are at the far end of his power cable, behind the camper, with exhausts pointing away from the site.
IF NOISE MATTERS MOST, then get a big one. At nearly $5000, the 7000 watt Honda might be priced like a used car, but it can supply a typical RV load without coming up much off idle. I witnessed this when a contractor parked nearby and had a big 6300 watt Yamaha inverter on the "toy hauler" rack on the tongue of his hybrid. It was shockingly quiet even with the AC on in his rig. But at nearly $3000 more than the Powerhorse/Predator, I'll bank that money and invest about $800 of it into a decent solar setup.
As the old saying goes,
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 05-11-2020, 04:28 PM   #15
Broken Toe
Cowracer's Avatar
Powerhorse
Model LC3500i
Honda
Model
C.B.
Dunno why you insist that noise level is the only consideration to use when looking at generators, but you information has been duly noted.
Tim
"Camper" 2016
Old 05-11-2020, 04:52 PM   #16
C.B.
I'm curious too, which units are you talking about under 50 dbl at 1/4 load?
Mike134 is offline   Reply With Quote
Old 05-11-2020, 04:57 PM   #17
This is great information! Coming from an audiologist, I put more value on this than the google experts. And what I gather is the generator the OP is referring to seems to be a good bang for the buck.
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 05-11-2020, 04:57 PM   #18
Now boys settle down. I have a 24,000 watt generator you can't even hear. Made by Duke Power. So there
05 Cummins 3500 dually 2014 Blue Ridge 3025RL
bucky53 is offline   Reply With Quote
Old 05-11-2020, 09:52 PM   #19
Maybe the way to work this out is to divide watts by decibels and watts by dollars?
My home standby comes out pretty good and itís a Kohler 50kw 3ph powered by a 7.5 Ford running at 1800 rpm.
aircommuter is offline   Reply With Quote
Old 05-12-2020, 07:15 AM   #20
C.B.
Please list a couple otherwise I'm starting to believe the "advise" on a forum is as good as the "advise" I get from my local saloon.
3500, 500, generator, inverter
