As mentioned above, if you have just one water heater switch inside, it is for LP use.
The second switch is usually for the water pump.
The electric element switch is located in the outside water heater compartment and often hard to see. (lower left corner) It sometimes gets turned on and forgotten about and then, somewhere along the line, if the water heater isn't full of water and the camper gets plugged into shore power, the element burns out. Always be aware of the switch position when setting up/breaking down camp where electric is available.
