07-21-2021, 08:43 AM
Thin Shade crap
I purchased an off brand set of thin shades for my TT. They were reasonably priced at $24 each. Install was a pain because of the screen door. Using them was equally as painful because you have to open the door, separate the screen door, climb down on the steps and then then reach up to pull the shade down. I'm sure that a taller person would have an easier time but nonetheless, it is still not convenient to have to do all of that to use the shades.
I stored my TT and came back a week later and both shades warped where they latch on inside the window. I can only assume that it was from the heat that was generated between the window and the black shade fabric. This rendered them unusable. I decided to buy the Lippert ones and paid $48 each! When I opened the package I was immediately pissed off because the name brand one was 99.5% identical to the off brand one I previously purchased. The only difference was the thickness of the string that is used to suspend the shade fabric, the Lippert string was thicker.
Has anyone had the same problem with their Thin Shades?
07-21-2021, 09:10 AM
Door Shade
Hello, I bought this one for my door window. It's easy to use and has held up really well for three years now. https://www.rossrvinnovations.info/window-shade/ The magnets stay on your screen door, and you can roll up the shade when not in use. Check out the website on what it looks installed. Hope this helps...
07-21-2021, 09:22 AM
Part-Time Campground Host
They also make an in-window shade. You have to replace the entire door window. We've had ours for a few years now and it still works great. You still need to open the door and move the screen door to move it up and down. Some folks install it upside down, so you can peek over it to see outside.
https://www.amazon.com/AP-Products-0...6877149&sr=8-5
Nor sure what camper you have, but it fits most standard TT doors.
Craig & Cath
Days camped since 2015(retirement): 1659
07-21-2021, 12:05 PM
Trailer Park Supervisor
My OEM thin shade is a piece of crap we never use, always leave it UP, because when you put it down, then try to put back up, it does not 'accordian' fold properly and gets all goofed up like a poorly folded map.
Yes, I drink the water!
07-22-2021, 09:04 AM
I had the same problem with the thin shades. Both of them did the same thing when you rolled them up. I thought it was just me.
I wish the thin shades had the same sturdiness that the other push up blinds have in my TT. My TT has a sky light with a shade. The shade is very sturdy. I thought the Thin Shade from Lippert would have been the same.
07-22-2021, 09:05 AM
And I thought it was just ME!
07-22-2021, 11:31 AM
The doors are already outfitted with the frame. It is not the same as the one you posted. All you have to do is install the thin shade.
07-22-2021, 11:32 AM
I just realized that its called a Slim shade and not a Thin shade. lol
07-23-2021, 03:50 PM
Have been happy with the AP products shade so far. Still the hassle of stepping out to get between the screen door and regular door to operate, but stays open till evening. Some have found a work around with a magnetic screen to replace the upper screen in the screen door. Think the AP runs around $65 to $75, wasn't a bad install, a little PIA to undo the clips on the oem interior section of the door window. Screws are used on the new unit. I ended breaking a couple clips on the oem, but don't intend to go back. Kept the frosted glass though as an emergency replacement.
