Old 07-02-2022, 11:03 AM   #1
Things you check yourself
Hearing all the different discussions about you have to be a little handy owning an RV. Being newbie’s to rving but having owner our trucking company for 52years. I like to crawl around under and all over our Rockwood 2891 BH. Just to know what might go wrong. A lot. So Friday I’m looking underneath and find the propane pipe going to the rear outside kitchen rubbing on the sun frame. Pictures after I finish. So installed some wire loom about 18 inches and that took care of it.
Trying to attach pic Click image for larger version
Rambling Kids is offline   Reply With Quote
Old 07-02-2022, 03:16 PM   #2
Thanks for posting the problem and the solution. Hopefully it will help someone else.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 07-02-2022, 03:27 PM   #3
jeff64's Avatar
They route wiring around frame gussets in a similar manner . If it wasn't such a PIA I'd like to see what horrors are under the coroplast.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 07-02-2022, 03:35 PM   #4
Don't watch the sausage being made....
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
fipntdot is offline   Reply With Quote
Old 07-04-2022, 02:41 PM   #5
MilCop4523's Avatar
a multitude of sins are hidden in most travel trailers.
we were sitting in out new trailer last year and my better half asked me how they anchor the wall panels to the interior structures.
i thought it was kind of a silly question until she went over to the mirror and pressed on the wall panel. when she did that the panel made a slurpy sort of sound. The panel was held on by the 1 inch of seam tape.
later that week the 8 foot long piece of trim over the recliners fell on us watching TV.
sometimes its better not to look for stuff that will make you upset.
OP - good find on the propane line and nice repair.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 07-04-2022, 09:07 PM   #6
Freetyme's Avatar
May want to check the LP line from tank/tanks to the undercarriage. I slit a section of 3/4 garden hose and wrapped and secured with zip ties around the LP hose which had been rubbing against the tank hold down. Also the pig tail connectors from tank to regulator need to be inspected periodically. Not sure how much gas I lost prior to smelling it while near the tanks. Not indoor at least so not critical.
Freetyme is offline   Reply With Quote
Old 07-05-2022, 12:00 AM   #7
SailorSam20500's Avatar
The front half of my coroplast pealed back on a trip down to Florida. What a mess. My heat ducts were dragging on the ground! I wire loomed a bunch and replaced 99% of the flex heat duct with rigid aluminum. I did end up with better air flow from the furnace...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
check
