Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-21-2018, 09:01 AM   #4381
Broken Toe
Cowracer's Avatar
Is it normal to have a single pole 50amp breaker for a 30amp plug?
I know we had to have consistently exceeded 30amps and it didn’t blow. Though I didn’t check the heat/warmth of the adapter.
I'm sure its not safe at all, but why does the cover plate look like it made a particularly difficult atmospheric re-entry from orbit? LOL
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 02-21-2018, 09:04 AM   #4382
BandJCarm's Avatar
Tim
And at a 45 degree angle, at that?
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 02-21-2018, 09:55 AM   #4383
Always Learning
Originally Posted by Evereddie View Post
OK. So your neighbor is in a 30 amp outlet running off of a 30 amp breaker. Your 30 amp camper is in an adapter which lets you plug into a 50 amp outlet running off of a 50 amp breaker. Hopefully it wouldn't blow since you are configured to 30 amps. Or is your camper a 50 amp? Confused why you are saying 30 amp breaker.
I have a 50amp camper.
The outlet is a 30amp receptacle.
I used a dogbone to adapt from 50 to 30 to plug in.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 02-21-2018, 10:01 AM   #4384
Attachment 163014
Tell us where you're at, so we can avoid it.
2011 Traverse LT, 3.6L, FWD
Old 02-21-2018, 10:08 AM   #4385
old40ford's Avatar
X2
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 02-21-2018, 10:22 AM   #4386
Always Learning
Winter Garden RV Resort outside of Orlando.
Old 02-21-2018, 10:34 AM   #4387
Next folks coming in who donít know are not going to like their stay, Iím thinking. If you really know what youíre doing on this I suppose itíd be okay, but I sure wouldnít be comfortable with it. Iím a little paranoid on my electronics on a good day.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 02-21-2018, 10:44 AM   #4388
Have you pointed out to management that they are probably not up to code? Maybe wait until you're leaving.
Old 02-21-2018, 10:48 AM   #4389
dbledan's Avatar
Attachment 162943
I know we had to have consistently exceeded 30amps and it didnít blow. Though I didnít check the heat/warmth of the adapter.
It looks like waves hit it?
I am no electrician (where are those guys?) but for single pole 50amp serving 30amp plug if the wiring is sized right back to the upstream box it is safe there. You can place a 15amp plug on a 20amp breaker assuming that there are more outlets to use the demand akd the wiring is sized correctly. I bet this is against a code somewhere because this is a dedicated 30A outlet.
You only need the double breaker if providing 220 service so a single breaker on 120 should be fine as long as plugs and wiring can handle the load.
I bet they were tripping 30amp breakers (they do this when they get old and in the heat/elements which this has seen) so they put in a 50amp. This would not be ok because now you can use too much power for the wire sizing. If they swapped a 50A 220 to a 30A single then that is better. Only way to know would be remove the panel...
dbledan is offline   Reply With Quote
Old 02-21-2018, 08:12 PM   #4390
Who Dares, Wins
doc73's Avatar
Was on fire and the paint burned off....
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 02-21-2018, 08:18 PM   #4391
Mr. Dan's Avatar
I guessing this is a good guess.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115; Booked for 2022 = 41
Old 02-21-2018, 11:17 PM   #4392
Evereddie's Avatar
I'm guessing that the 30 amp outlet that Doug is in was originally a 50 amp outlet and used both 50 amp breakers. For whatever reason it was replaced with a 30 amp ( single phase) outlet. That is why you only need to turn on one of the 50 amp breakers. Also bet that in it's original configuration the empty breaker slot had a 15 or 20 amp breaker in it and it feed the missing standard outlets. (since removed) Yes Mr. MOTO ain't I.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 02-22-2018, 10:10 PM   #4393
SailorSam20500's Avatar
At Travelers World RV Resort in San Antonio TX.
Others have posted of folks with similar setups. This couple has it covered, a SMART car for rainy days, a Harley for sunny days, a nice big trailer, and a TV the weight police will be comfortable with. I THINK the sign goes with this site, it was a week or so ago and my remembery is a bit fuzzy... In any case, I resemble the remark.
ID:	163115   Click image for larger version
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 02-22-2018, 10:13 PM   #4394
Saw this at the Galloping Snail RV park in Bryan Tx.
Again, something like this has been mentioned before, my DW told me to remember these tips...
Al
Old 02-22-2018, 11:18 PM   #4395
I posted on this earlier... Couple ran into a bird that shattered their windshield. They taped the inside with clear packing tape before they pulled out. Not sure if they went directly to somewhere to get it fixed or continued their trip.
I've given up trying to get my cell phone pics to post correctly...
Al
Old 02-22-2018, 11:23 PM   #4396
I'd bet they had to go somewhere to get that fixed; I'm guessing that's not a windshield your local Safelite auto glass place would stock!
Old 02-22-2018, 11:36 PM   #4397
Kaadk's Avatar
Is that dblrís rig? I know heís got a setup like that and I heard heís gotten a Riverstone since I last saw him.
Old 02-22-2018, 11:42 PM   #4398
Originally Posted by Kaadk View Post
Is that dblr’s rig? I know he’s got a setup like that and I heard he’s gotten a Riverstone since I last saw him.
I had the same thought, but I didn't think he had motorcycle.
Old 02-23-2018, 12:12 AM   #4399
Director, FROG
F.R.O.G.'s Avatar
That might not be so far-fetched. The photo of the 30-amp outlet looks as if it might have overheated and partially melted at the lower two inputs.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 02-23-2018, 01:13 AM   #4400
You would be surprised at what safelite has in their warehouse. They keep very few at the local store but within a few days just about anything made in the last few years can be had.
Last time I had a windshield replaced by them they had a stack of bus and rig glass at that shop because of a contract they had
Jmkjr72 is offline   Reply With Quote
