Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-23-2018, 09:51 AM   #4401
Originally Posted by Jmkjr72 View Post
You would be surprised at what safelite has in their warehouse. They keep very few at the local store but within a few days just about anything made in the last few years can be had.
Last time I had a windshield replaced by them they had a stack of bus and rig glass at that shop because of a contract they had
Maybe it didn't fit in the truck?
2011 Traverse LT, 3.6L, FWD
Old 02-23-2018, 09:51 AM   #4402
Originally Posted by Kaadk View Post
Is that dblrs rig? I know hes got a setup like that and I heard hes gotten a Riverstone since I last saw him.
Originally Posted by rockfordroo View Post
I had the same thought, but I didn't think he had motorcycle.
Sorry guys that's not us, plus the camper is a Redwood. Nice set up they have. Yes we did get a new River Stone Legacy and no on the motor cycle, not enough room on our truck for a bike and the Smart
dblr is offline   Reply With Quote
Old 02-23-2018, 10:14 AM   #4403
Broken Toe
Cowracer's Avatar
Cut the sleeper off the tractor, plenty of room for a bike. I can bring a sawzall to Goshen.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 02-23-2018, 10:23 AM   #4404
BandJCarm's Avatar
You have a motorcycle?
If so, leave wife home.
You can thank me later.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 02-23-2018, 10:32 AM   #4405
Broken Toe
Cowracer's Avatar
Originally Posted by dbledan View Post
It looks like waves hit it?
I am no electrician (where are those guys?) but for single pole 50amp serving 30amp plug if the wiring is sized right back to the upstream box it is safe there. You can place a 15amp plug on a 20amp breaker assuming that there are more outlets to use the demand akd the wiring is sized correctly. I bet this is against a code somewhere because this is a dedicated 30A outlet.
You only need the double breaker if providing 220 service so a single breaker on 120 should be fine as long as plugs and wiring can handle the load.
I bet they were tripping 30amp breakers (they do this when they get old and in the heat/elements which this has seen) so they put in a 50amp. This would not be ok because now you can use too much power for the wire sizing. If they swapped a 50A 220 to a 30A single then that is better. Only way to know would be remove the panel...
I am an electrician. Actually an electrical engineer, so maybe not as good as an actual electrician, but close.
Protective devices ONLY protect the wires and components downstream of those devices. If the feeder sending power to that pedestal short-circuits, that breaker most likely won't (and shouldn't) blow.
You cannot use 14ga wire (rated for 15a) on a 20amp breaker in your house under any circumstances. No matter how many outlets on the circuit.
I spend a WHOLE lot of time working on proper circuit coordination. Meaning, if a motor in my plant shorts out, I want it to blow the fuses or breakers for that motor only. I don't want it to blow the feeder fuses and take down a whole section. And I sure as hell don't want it to blow the incoming mains. (shudder) And when I say 'motor', I'm talking 1500HP 2300volt biggies. I got a great video of what happens when the circuit coordination goes wrong.
Tim
"Camper" 2016
Old 02-23-2018, 10:46 AM   #4406
26RR's Avatar
Our first camper. 1968 Serro Scotty Sportsman Gaucho. A RV Park owner liked it so well, she bought it from us, and has it on display in her Park. Now, all that go there can enjoy seeing this beauty.
2017 F250 XL, Supercab, 6.2L Gas w/Tow Pkg
2017 Grey Wolf 26RR Limited, Toy Hauler
2016 Cricket Mini Golf Cart[SIGPIC]
26RR is offline   Reply With Quote
Old 02-23-2018, 10:53 AM   #4407
Tim
I guess this means we need to keep a close watch on you at Goshen, or maybe find you a different parking place.......just sayin I know a guy who knows a guy that could make things happen.
Old 02-23-2018, 10:54 AM   #4408
Originally Posted by 26RR View Post
Attachment 163166
Great old camper, must be nice to see it on display like that
Old 02-23-2018, 11:05 AM   #4409
Attachment 163166
50 years old! I guess you just dated yourself!
Old 02-23-2018, 11:24 AM   #4410
Originally Posted by Bluepill View Post
All this crazy talk about TT parks and the zany rules makes me glad I'm a member in good standing in the Wally Docking Association......
Just like Outback Steak House - "No Rules"
Quite Hours? Never.
Generator Hours? Anytime.
Reservations? Not needed.
Check in time? Whenever.
Check out time? Whenever.
Hookups? Sorta. As much water as you can afford to buy.
There are a lot of them who have stopped allowing this, or setting other rules like.. no generators. Trying to remember where I read that awhile back so I can back it up instead of looking like I am just running my mouth.....
tlspencer is offline   Reply With Quote
Old 02-23-2018, 05:56 PM   #4411
Not in a campground and probably won't make it there.Click image for larger version
BigGuy87 is offline   Reply With Quote
Old 02-23-2018, 06:45 PM   #4412
SecretSquirrel's Avatar
It's not the Wallymart but locals who prevent it. The Wally in Mechanicsville VA doesn't allow overnighting but it's the county preventing it due complaints supposedly from neighbor's.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 02-23-2018, 06:52 PM   #4413
Around my hometown just about all the big parking lots are off limits for overnight stay.
As cost of living went up so did the cost of housing for low income families. A lot of them bought (or were given) worn out old RV's and their "Overnight Stay" would turn into several weeks.
Just about every industrial area in Seattle as well as any place one can park under the freeways or bridges has an old 70's vintage RV parked. Several fires have forced the authorities to block off areas under bridges and overpasses but the residents just move to another spot and stay until kicked out there too.
It's not just the local RV parks that have campaigned for laws against spending the night in a Walmart parking lot, it's the cities trying to keep them from becoming another homeless camp.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 02-24-2018, 11:24 AM   #4414
dbledan's Avatar
Safety first!Click image for larger version
dbledan is offline   Reply With Quote
Old 02-24-2018, 03:48 PM   #4415
old40ford's Avatar
Safety first!Attachment 163250
And probably some poor sole will just wade in and hook up his rv.
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 02-24-2018, 07:19 PM   #4416
SailorSam20500's Avatar
Talk to my DW, she's Sicilian and has relatives in both cement and vegetables...
Al
Save the Earth. Its the only known planet with Beer.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is online now   Reply With Quote
Old 02-24-2018, 07:37 PM   #4417
Always Learning
Ive stood in ankle deep water before to hook up electric.
Frog strangling tornado watch mess of a storm came thru as we were getting 2 campers parked. We abandoned one in the road to seek the bathhouse to wait out the watch (or is it warning?).
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 02-24-2018, 07:46 PM   #4418
Kanadian Kamper
kenandterry's Avatar
ependydad....
Where are you standing?
Maybe its a marina and not a campground
Ken and Terry
2018 Sunseeker 2430S-CD over a 2017 Ford E450
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 02-24-2018, 07:52 PM   #4419
Looks like he is walking on water
msdundas is offline   Reply With Quote
Old 02-24-2018, 08:39 PM   #4420
Bluepill's Avatar
I’ve stood in ankle deep water before to hook up electric.
Attachment 163297
I was in that situation once. I chose to use the generator. I figured that if anyone came around complaining, I would offer them my shore power cord and tell them if they would be kind enough to plug it in for me, I would shut down my genny and/or call 911 for them.
One problem with 30 amp and 50 amp services is that there is no GFI protection at the power pedestal. And based on the condition of many 20 amp GFI outlets, I would not trust them either.
I finally shut the genny down at about 11PM, after my batteries were all charged up and we didn't need any more 120 volt power.
